Toymods » Tech & Conversions » 3tgte boosting problem...
freakincage_com
north brisbane
3tgte boosting problem... Sat, 09 July 2005 08:36 Go to next message
hey guys...i was woundering if anyone with a stockish 3tgte could help me...wen i rev my engine...and it hits boost...the vac drops from about 20 to 0...but no boost?i rev it up to 7 or so but it just stays at 0....i have tried hooking up a boost controller and playing around with adjustments...but still no luck...i have a plum back b.o.v and you can see the piston inside relise wat i asume is some sort of boost when you back off the throtle.....whats goin on??
berad
Re: 3tgte boosting problem... Sat, 09 July 2005 09:13 Go to previous messageGo to next message
check that the valve in the bov is not seized open
freakincage_com
north brisbane
Re: 3tgte boosting problem... Sat, 09 July 2005 09:22 Go to previous messageGo to next message
its not....you can see its closed and when u relese the throtle it opens up a tiny bit.....???
berad
Re: 3tgte boosting problem... Sun, 10 July 2005 00:44 Go to previous messageGo to next message
when you release the throttle it should open up depending on what tension you have on the spring. have you got the vacum line connected to your inlet manifold ?
freakincage_com
north brisbane
Re: 3tgte boosting problem... Sun, 10 July 2005 01:03 Go to previous messageGo to next message
yes,when u reliese the throttle, u can see the b.o.v open slightly.....yes the vac line is on..and the boost gauge is set up right.....now what....
Re: 3tgte boosting problem... Sun, 10 July 2005 02:00 Go to previous message
Check wastegate isn't stuck open.
You didn't say in the other thread re. this same problem. If it actually makes any boost? In the seat test.. Not looking at boost guages.
[Updated on: Sun, 10 July 2005 02:01]
Previous Topic:MS55 Crown Vented Disks??
Next Topic:3tc dizzy point wanna make it electronic
Current Time: Thu Nov 19 17:58:13 UTC 2026
Total time taken to generate the page: 0.0055398941040039 seconds
