Classifieds » Car/Engine Electronics & Audio » 6 540CC SARD low Impedance injectors $450
Wizzard
6 540CC SARD low Impedance injectors $450 Sun, 10 July 2005 09:57 Go to next message
Hiya as title says,
6 x 540CC SARD low impedance injectors. Side feed.
Checked impedance personally all withing .1 ohm around 3 ohm.
$450
[Updated on: Thu, 14 July 2005 10:55]
dv8one
February 2005
Re: 6 540CC SARD low Impedance injectors $450 Mon, 29 August 2005 12:38 Go to previous messageGo to next message
What engine are these for?
Wizzard
Re: 6 540CC SARD low Impedance injectors $450 Tue, 30 August 2005 00:56 Go to previous messageGo to next message
1JZ or 2JZ.
Side feed, but low impendance. Peak and Hold injectors. 3ohm.
MR 1JZ
Re: 6 540CC SARD low Impedance injectors $450 Thu, 01 September 2005 02:11 Go to previous messageGo to next message
how do you change the impedance, I was aware that stock impedance on a 1JZ is about 13 ohms...
Wizzard
Re: 6 540CC SARD low Impedance injectors $450 Thu, 01 September 2005 02:55 Go to previous message
I have already bought myself 3 resistors, 5ohm 50Watt suckers. I will wire them up inline with the injectors 12+ lines. A 1JZ is a dual firer (2 cylinders at once, so only 3 resistors needed). Pretty much I just am going to make my own resistor pack....
In the resistor pack you get 6 x 10ohm. Which takes the 3ohm up to 13ohm or so.
If you have dual you just need a 5ohm, but you need a large wattage resistor and good heatsink.
So yeah I was advertising to sell these ages ago, and decided to keep them and put them in my car. If someone buys them, well that's great...if they don't it doesn't bother me.
I will sell them down the track with ready made resistor pack Smile will work on any 1J, or 2J.
The rumour is that peak and holds give better response even in this setup (with resistor pack) than high imp. injectors...but that could just be bullcrap.
Previous Topic:460cc injectors top feed low impedance $35 each
Next Topic:2 12" pioneer in box
Current Time: Sun Nov 1 06:02:07 UTC 2026
Total time taken to generate the page: 0.0060219764709473 seconds
