Toymods » Tech & Conversions » Which Microtech for 3TGTEU?
riceburna73
Which Microtech for 3TGTEU? Mon, 11 July 2005 00:27 Go to next message
I have recently made a good contact who can get me a new microtech at cost and yes get it mapped to suit.But which one?I have never looked into them as I thought they werent going to suit the engine..
Re: Which Microtech for 3TGTEU? Mon, 11 July 2005 00:42 Go to previous messageGo to next message
LT8S should cover it.
Does the 3T-GTEU just use a single channel ignitor and the dizzy distributes the spark?
Are you converting to coil pack?
Do the plugs fire as pairs? or leading/trailing?
riceburna73
Re: Which Microtech for 3TGTEU? Mon, 11 July 2005 01:01 Go to previous messageGo to next message
Mate I have no idea Confused
If anyone can help answer the above it would be appreciated
slonlo
auckland new zeland
Re: Which Microtech for 3TGTEU? Mon, 11 July 2005 05:26 Go to previous messageGo to next message
single channel fired in pairs
Re: Which Microtech for 3TGTEU? Mon, 11 July 2005 05:39 Go to previous messageGo to next message
There you go.
LT8S, set up like any 4cyl with same firing order and one ignitor channel.
pheonix83
Devonport Tasmania
Re: Which Microtech for 3TGTEU? Mon, 11 July 2005 07:35 Go to previous messageGo to next message
mt4 or lt4.
As it doesnt use a computer for ignition.
unless you convert it.
Re: Which Microtech for 3TGTEU? Mon, 11 July 2005 07:45 Go to previous messageGo to next message
You'd be silly to convert a motor to aftermarket ecu and not convert it to ignition control.
sideshow
Re: Which Microtech for 3TGTEU? Mon, 11 July 2005 08:56 Go to previous messageGo to next message
go for the shinny black one they arent as fast as the red ones thou
TA22 GT
Re: Which Microtech for 3TGTEU? Mon, 11 July 2005 11:00 Go to previous messageGo to next message
Microtech LTX8 is the way to go. Gives you the flexibilty of using stock coils and dizzy or aftermarket coils and crnak angle sensor.
Cya,
Simon
NickZ
Launceston
Re: Which Microtech for 3TGTEU? Mon, 11 July 2005 13:46 Go to previous messageGo to next message
I have a 2T-GEU and used a Microtech MTX8 for a 4AGE 20 valve, I modified a 20V Crank angle sensor for signal for the Microtech and used multicoil setup in wasted spark configuration using 2 VN series 2 coil packs controlled by the Microtech.
In your case you could use the the 4 coil outputs to run 4 commodore coils to fire 2 plugs per cylinder.
but you will have to modify the dizzy the way i have or use a toothed wheel on the crank for signal.
Click the link on my signature to see my dizzy setup.
riceburna73
Re: Which Microtech for 3TGTEU? Tue, 12 July 2005 03:31 Go to previous messageGo to next message
OK so thgere are obviously a couple of options:
LTX8
MTX8
MT4
LT4
LT8S
Sorry guys I have no idea about any of this stuff,I dont want to go to the trouble just yet, of changing to different coils or spark sequence all i want is to run a high flowed CT20 on 12psi and have a nice power delivery/drivability..
Re: Which Microtech for 3TGTEU? Tue, 12 July 2005 03:36 Go to previous message
Its LT8S now for the new one.
Don't bother with the LT4 series as for an extra $300 you'll get full ignition control.
For another $100 you'll get 2 extra outputs too (not sure if you'll use them)
DO NOT get an MT series stuff.
Order it for what you want, and build the motor up for that.
Don't order it for what you have, because it will cost you extra to get it converted in the future.
ie, if you want coilpacks, order it with coilpacks now, and convert the car to coil pack. It you order it for dizzy, then convert it to coilpack later, it will cost you $80 to get it reprogrammed.
To reinterate, LT8S
http://www.microtechefi.com/html/LT.htm
Previous Topic:VIC/ MELB WORKSHOPS
Next Topic:Best Brake Pads For MX83 - What do you use??
Current Time: Fri Nov 20 20:46:47 UTC 2026
Total time taken to generate the page: 0.017329931259155 seconds
