Toymods » Tech & Conversions » Tyre Pyrometer's
Tyre Pyrometer's Mon, 11 July 2005 05:34 Go to next message
Howdy all, well i'm thinking in preperation for the next track day i'll invest in something to measure tyre temps.
Would like to get more of an idea if i'm running correct pressures, camber, etc.
I've been looking around for a pyrometer, and what confuses me is companys like Longacre make devices just for this purpose eg - http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&a mp;category=35625&item=4534166549&rd=1& ;ssPageName=WD1V
But then you can get something for less than half the price from Jaycar. - http://www1.jaycar.com.au/productView.asp?ID=QM160 0&CATID=&keywords=temperature&SPECIAL= &form=KEYWORD&ProdCodeOnly=&Keyword1=& amp;Keyword2=&pageNumber=&priceMin=&pr iceMax=&SUBCATID=
Is there actually a difference? Or do you just pay more for the longacre one because its for a 'race car'.
Joel
M.W.P.
Rocky Mountains, Canada
Re: Tyre Pyrometer's Mon, 11 July 2005 16:54 Go to previous messageGo to next message
Ive got that Jaycar digital thermometer...
Probably no reason why you couldnt use it to read tyre temperature.
Its quite accurate and responds quickly.
You woud probably have to make up somthing to hold the temp probe to press it onto the tyre.
Its a tiny blob of metal (the thermocouple) held by two wires, so it can bend around easily.
Roundy
Dubbo
April 2005
Re: Tyre Pyrometer's Tue, 12 July 2005 00:16 Go to previous messageGo to next message
i know u can get ones that are like a gun. Point it at the tyre and press the trigger and gives u a temp reading, no idea how accurate it is, but as u are looking at variances more then actual temp as long as it is consistent it won't matter!
I have seen people use it with go-karting to check the tire temps (why i have no idea) tho i couldn't tell u a brand or where to get it Embarassed
takai
Re: Tyre Pyrometer's Tue, 12 July 2005 01:49 Go to previous message
Yeah, Jaycar sell the IR pyrometers. Not bad, but you really want to be measuring the core temp of the tyre (i.e. with a spike below the surface), not the surface temps.
That said, you can get some vague sort of readings with the IR pyros, enough at least to compare between different setups.
Previous Topic:Plz Help Identify this! Pics inside
Next Topic:TA22 and RA23 rear suspension? identical or different (no love from search)
Current Time: Mon Oct 19 21:45:11 UTC 2026
Total time taken to generate the page: 0.0046889781951904 seconds
