Toymods » Tech & Conversions » 2tgeu fuel rail hitting dizzy???
lilcrash
ipswich queensland
2tgeu fuel rail hitting dizzy??? Mon, 11 July 2005 23:11 Go to next message
i cant move my dizzy to set the timing cause my dizzy hits my fuel rail.
why is my dizzy hitting my fuel rail?? both are standard factory items. i have put a link to a pic.
http://img272.imageshack.us/img272/2207/11313546ni .jpg
thanx
pheonix83
Devonport Tasmania
Re: 2tgeu fuel rail hitting dizzy??? Tue, 12 July 2005 08:17 Go to previous messageGo to next message
your dizzy isnt out a tooth ? so you have to wind it so far around to get the timing right ?
NickZ
Launceston
Re: 2tgeu fuel rail hitting dizzy??? Tue, 12 July 2005 08:59 Go to previous messageGo to next message
You have the wrong dizzy...I had the same problem. There are two types, my points dizzy was shorter than my electronic dizzy.
the clip for the cap also hits the injector.
I did end up using the shorter dizzy but modified it for hall effect for my original fuel injection setup.
I cut off the vac advance so the dizzy would spin around more and cut off the slotted bolt hole on the bottom and used a 4K dizzy clamp to hold it in place.
[Updated on: Tue, 12 July 2005 09:00]
lilcrash
ipswich queensland
Re: 2tgeu fuel rail hitting dizzy??? Tue, 12 July 2005 10:28 Go to previous messageGo to next message
the dizzy is sittin so the bolt is in the middle of the slide cut out bit. the dizzy just says 2tgeu on the lil sticker so im not sure. i dont really want to run a points dizzy with turbo whick is where my problem comes in cause i need to retard it for boost and i cant get a vac/boost diaphragm.
thanx for the help neway
NickZ
Launceston
Re: 2tgeu fuel rail hitting dizzy??? Tue, 12 July 2005 10:57 Go to previous messageGo to next message
Well there is nothing you can do, Youll have to find the taller dizzy. Both my dizzys have the 2T-GEU sticker on them.
But if you look at the link in my signature for my car youll see what i have done with my dizzy and get some ideas on whats possable.
lilcrash
ipswich queensland
Re: 2tgeu fuel rail hitting dizzy??? Tue, 12 July 2005 11:15 Go to previous message
thanx for that.
i think i will just go see that guy and get a new dizzy built for boost so yer.
laterdays
Previous Topic:rough estimate for panelbeating costs on cressida
Next Topic:2.7 litre corona
Current Time: Fri Nov 20 18:00:04 UTC 2026
Total time taken to generate the page: 0.0044980049133301 seconds
