Toymods » Tech & Conversions » G series diffs
1JZ.747
Osama's hideout
G series diffs Tue, 12 July 2005 02:16 Go to next message
Hi All
my g series lsd in the cressida is losing its LSD effect, ie going back to one wheel under load during the tyre warm up at the drags.
i was speaking to southo today and he told me these could be shimmed up tighter. has anyone had this done if so what are the results?
or if there are any other suggestions i would be greatful for the tips.
until i can get some thing done about the LSD i will most likely weld up a locker for jamboree as its the cheap option with all the costs of jambo coming up. transport, cage, fuel etc.
shane.
ozzy31
Edmonton, AB
June 2005
Re: G series diffs Tue, 12 July 2005 02:38 Go to previous messageGo to next message
I'm curious to hear a response. I don't have first-hand experience, but I thought shimming it up meant adding an additional clutch disc (usually robbed from another spare rear-end)...
1200det
Re: G series diffs Tue, 12 July 2005 04:09 Go to previous messageGo to next message
I had mine fully rebuilt with new bearings etc last week , Instead of extra shims from Toyota the diff place actually used large washers of some sort they get made up.
All i can say is its basically a locker now Smile
Re: G series diffs Tue, 12 July 2005 04:30 Go to previous messageGo to next message
It's a simple procedure which any diff shop should be able to do. If shimmed to factory specs it should be as good as new, but it's also possible to get it shimmed tighter which will make your diff almost feel like a locker... but the downside is the clutches wear faster.
One thing to note, if your clutches are already worn past the allowable limit no amount of shimming will help you... and I'm willing to bet new clutches aren't cheap.
1JZ.747
Osama's hideout
Re: G series diffs Tue, 12 July 2005 04:52 Go to previous messageGo to next message
Norbie wrote on Tue, 12 July 2005 14:30
say the clutches are rooted, what do you suggest norbie.
look for a ma70 and get the guts changed over?
buy a jap centre?
get something from a hilux?
i value your opinion.
[Updated on: Tue, 12 July 2005 04:58]
Re: G series diffs Tue, 12 July 2005 05:02 Go to previous messageGo to next message
If it was me I'd buy a used G series LSD centre.... doesn't really matter where it comes from, but remember you're taking a gamble because a used LSD could be just as "used" as yours is. If you can find it a JZA70 torsen centre is the best bet, no clutches or other wear components to worry about. Smile
Allan
Re: G series diffs Tue, 12 July 2005 05:04 Go to previous messageGo to next message
how about a trutrac they are apparently available for G series centers?
1JZ.747
Osama's hideout
Re: G series diffs Tue, 12 July 2005 05:07 Go to previous messageGo to next message
jza70 guts will fit inside my housing norbie?
true trac?
Allan
Norbie wrote on Tue, 12 July 2005 15:02
JZA70 torsen centers dont like drag use...
http://mkiiitech.com/drj/blownupstuff/torsenclose. jpg
Allan
Re: G series diffs Tue, 12 July 2005 05:08 Go to previous messageGo to next message
norbie has a F series true trac in his jza61 AFAIK?? norbs?
Re: G series diffs Tue, 12 July 2005 06:50 Go to previous messageGo to next message
New clutch packs, new spring, thicker washer to shim up spring.
What about new full mechanical G ceries centre from TRD - about $1800 clams?
Re: G series diffs Tue, 12 July 2005 23:29 Go to previous messageGo to next message
Allan wrote on Tue, 12 July 2005 15:08
Correct, and yes they are available for the G series as well. There are a range of aftermarket clutch-type centres available as well, and even Detroit lockers and air lockers. All this is thanks to the 4WD Hilux which has a G series rear diff, and thus there are upgrade options galore for the rock-hopping nut-jobs.
1JZ.747
Osama's hideout
Re: G series diffs Wed, 13 July 2005 00:45 Go to previous messageGo to next message
Norbie wrote on Wed, 13 July 2005 09:29
whats a true trac worth norbie?
Re: G series diffs Wed, 13 July 2005 01:41 Go to previous messageGo to next message
Should be able to land an F series for $7-800 from the US. G series may be a little more, haven't priced them though.
Toyo Truck
    I ain't no JABBER!
Re: G series diffs Wed, 13 July 2005 03:01 Go to previous messageGo to next message
Hey whats wrong with Rock-hopping Norbie??
Its all in the name of fun! Evil or Very Mad Cool Shocked
But yeah I just picked up a shagged LSD for free off
my 4wd mate who also has a hilux.
with 38"x15" tyres at 8psi, twin diff locks and 70:1 reduction
only managed to strip 2 teeth off the pinion and broke 3 - 4
teeth off the crown. He still drove all the way from Nowra to
penrith with the diff in this condition at 80 kmph.
So these things are tough! No way you'll come close to this
with street tyres. IRS axles will die well before the centre does.
Where is a good diff place to go to for the shim-up and reco in the Sydney area? What is a good price for this job on an LSD
centre??
Cheers guys,
Bart
TheStitt
Membership Secretary
Re: G series diffs Wed, 13 July 2005 08:47 Go to previous messageGo to next message
I'm really happy with the True Trak in the back of the wagon.
However it is only an F series so I can't help with price of the G sereis.
as for a Diff guy call John 9671 5800. He is out near eastern creek he installed my true trak into my centre and did a great job.
Toyo Truck
    I ain't no JABBER!
Re: G series diffs Wed, 13 July 2005 23:40 Go to previous messageGo to next message
Thanks mate,
I'll give him a call today to find out.
Oi whats the go with these "True Trac" centres??
How are they different to normal toyo LSD and what
effect does it have when driving? Is it more like
a locker or just a better LSD?
Is it a whole centre, or does it only replace the clutch
discs inside the LSD centre?
Bart
Re: G series diffs Wed, 13 July 2005 23:46 Go to previous messageGo to next message
It's just the centre. It replaces the spider gears and clutch packs with a helical gearset. Kind of hard to explain but if you go to www.howstuffworks.com I think they have some info on the different types of LSD.
When driving it's no different to the OEM clutch LSD except it's more consistent and locks up a little more (in my experience). The only downside is you lose the LSD effect if you lift a wheel, which can be a problem for 4WD applications I guess.
TheStitt
Re: G series diffs Thu, 14 July 2005 04:43 Go to previous messageGo to next message
What Norbie said.
Its A torsen type LSD/Centre for when you look it up on howstuffworks.
They are pretty tight and they don't really wear out not like clutch limo's do.
1JZ.747
Osama's hideout
Re: G series diffs Mon, 25 July 2005 04:19 Go to previous messageGo to next message
ok, so on the way to the chasis shop on saturday the diff went al but completely. any load it just slips like a bitch.
going to weld one up, havent had any luck with a true trac, i seem to run into a dead end where ever i go, i have spoken to several Diff specialists and they all just scratch their head and say to hard, dont want to know.
EvilJack
Sutho/Hills NSW
Re: G series diffs Mon, 25 July 2005 04:28 Go to previous messageGo to next message
so its never been rebuilt since you have owned it? its done pretty well for itself if thats the case Razz
John from importbitz seems to get the jza70 torsen centres frequently, http://importbitz.com/mechanical.htm one just sold here
then all you should have to do is get the crown wheel swapped from the mx83 diff to the supra diff
speak with JasonP on cressida forums as he has had this done
dcving
newcastle nsw
Re: G series diffs Mon, 25 July 2005 04:45 Go to previous messageGo to next message
shane, try places in newcastle such as out of town 4wd, opposite lock ect, they should be able too help you out with after market centers ect. Smile
1JZ.747
Osama's hideout
Re: G series diffs Mon, 25 July 2005 05:27 Go to previous messageGo to next message
dcving wrote on Mon, 25 July 2005 14:45
i tired newcastle gearbox and diff and promac, neither wanted anything to do with it. i tried a few 4wd places but they werent confident about the application.
i have spoken to john at importbitz and he is getting me a torsen mechanical centre froma jzx100. and we shoul dhave it prior to jamboree.
Blackers
Forrestdale W.A.
Re: G series diffs Mon, 25 July 2005 07:01 Go to previous messageGo to next message
There seems to be a lot of conjecture as to whats avaliable for these diff centres. Hilux with the 30 spline axles have a myriad of different locking type centres. I have in my AE86 (yes it has a modified hilux diff with 30 spline axles) a LOKKA mechanical type centre that I bought s/h off ebay for $400 but they should be avaliable from nearly all good 4wd shops. This centre works on a ramp type/dog tooth engagement which only allows 1 wheel to turn if there is no load on it ie around slow carpark stuff. When it engages there is NO slip as the dog teeth engage and effectively turn it into a spool type centre, they can only unlock under a release of load to both wheel.
LOKKA is distributed by 4wd Systems, 599 North East Rd, Gilles Plains South Australia.
Hope this helps
Mark
ke382TG
Re: G series diffs Mon, 25 July 2005 07:07 Go to previous messageGo to next message
could you give us a bit of a review on how it feels to drive mate? I have only known one person who has used this type.
Do you "feel/notice" the engagement of this type of diff when it goes from open to locked?
How does it respond if you get on/off the gas mid corner etc.
A little review on how you find this type of diff centre would be great Very Happy
Cheers.
Allan
Re: G series diffs Mon, 25 July 2005 07:41 Go to previous messageGo to next message
1JZ.747 wrote on Mon, 25 July 2005 15:27
post pics of when it falls to bits, i dought that its any different to a jza70 one
Blackers
Forrestdale W.A.
Re: G series diffs Mon, 25 July 2005 09:34 Go to previous messageGo to next message
This diff centre is very aggressive in it's actuation and I have learnt how to drive around it. Should you get on and off the gas mid corner, it will unlock and lock again causing you to spin (ahh the fond memories of first driving it.... NOT) should you get off the gas and it unlocks you will have to wait till the car is straight again (or more under control) to really get back into it. I like it as it wont ever break and it drives really well on the street for every day stuff. I haven't had it at the track yet but as soon as the opportunity arises I'll get stuck in and see how it goes, it works great for drag raycin/traffic light duels etc. You can definitely feel it engage on the street, it's a bit clunky but I can put up with the noise even though it's a little disconserting at first.
Mark
1JZ.747
Osama's hideout
Re: G series diffs Mon, 25 July 2005 23:36 Go to previous messageGo to next message
Allan wrote on Mon, 25 July 2005 17:41
it is the same as a jza70 one allan, great to see another positive person around the place.
Allan
Re: G series diffs Mon, 25 July 2005 23:50 Go to previous messageGo to next message
dude its PROVEN they dont last under drag use, i showed you photos if you had done some research you will find anyone that takes a torsen diff to the drag strip blows it up.
if you want me to bullshit you and say it will be great your dreaming, try a mechanic or a sales man if you want that kind of crap
have a nice day
rob_RA40
c'town, NSW
Re: G series diffs Mon, 25 July 2005 23:54 Go to previous messageGo to next message
perhaps allan is going about promoting discussion on the subject the wrong way
how would a multiplyer diff like a torsen be more effective on a drag car than a clutch, spool or locker?
0 torque x n = 0 torque transfer
1200det
Re: G series diffs Tue, 26 July 2005 00:43 Go to previous messageGo to next message
I was always under the impression that the Torsen G series also just dont last for drag racing use
I dont know from Experience im using heavily clutched G series and TRD 2 Way G series
..J..
opening a can of whoop ass
Re: G series diffs Tue, 26 July 2005 00:48 Go to previous message
i thinks its about longgevity.
a clutch type will have clutches wear out where as a torsen doesnt have clutches to wear out. i believe that is the problem not about the acutal lighting up of 2 tyres.
Previous Topic:fuel pump stuff
Next Topic:Who'd have thought an F-series diff...
Current Time: Sat Nov 21 07:20:00 UTC 2026
Total time taken to generate the page: 0.013813018798828 seconds
