Toymods » Tech & Conversions » 4AC compare to 4AFC
pepsicola
4AC compare to 4AFC Tue, 10 December 2002 13:59 Go to next message
What's the power difference between them?
I know for the 4AC, the intake and exhaust is on the same side.
Is the 4AFC the same?
Do they have the same block?
M.W.P.
Rocky Mountains, Canada
Re: 4AC compare to 4AFC Tue, 10 December 2002 14:38 Go to previous messageGo to next message
The 4A-F is a narrow-angle twincam, hence it will be xflow (exst on the other side from intake).
I dont think a "4A-FC" exists?
4A-C is around 70Hp @ 4800RPM.
4A-F is 90Hp @ 6000RPM.
Both do use the same block.
[Updated on: Tue, 10 December 2002 14:41]
pepsicola
Re: 4AC compare to 4AFC Tue, 10 December 2002 14:46 Go to previous messageGo to next message
so i mean a 4af carby out of a ae92.
EvilJack
Sutho/Hills NSW
Re: 4AC compare to 4AFC Tue, 10 December 2002 22:04 Go to previous messageGo to next message
4AFC is the twin cam isnt it? or is there a single cam and twin cam version of the 4AFC?
haggis
Re: 4AC compare to 4AFC Wed, 11 December 2002 00:03 Go to previous messageGo to next message
The 4A-FC does exist, and yes, its a carby 4A-F from an AE92.
All are twin cams but they have a single cam belt to one cam shaft, than a cog from one cam to the other, so its greatly different from a 4A-GE.
It is a x-flow head, which means in a FWD car, intake at the back, exhaust at the front.
Same block as a 4A-C, so it will mate up with the C5* gearboxes, and use the same drivers side engine mount.
FWIK all engines in an AE92 are unleaded, but i may be wrong (still driving an LRP car *sigh*)
Craig.
Richard84
Central Coast, NSW
Re: 4AC compare to 4AFC Wed, 11 December 2002 01:51 Go to previous messageGo to next message
4A-FC does exist. As haggis pointed out they're the carby engine from an AE92 (I should know being blessed with one Mad )
They are all twin cam. You guys should know how to read Toyota engine codes, come on! The 'F' stands for economy, in other words, twin camshafts. Narrow angle cams as pointed out earlier by M.W.P. The 'G' in 4A-GE or 1G-GTE or 2JZ-GTE means wide angle twin cams.
They aren't bad. A decent torque line and they are plenty quick enough in the city (but not for fun or our egos). The best thing is they're an easy engine to tune and play with yourself, which I'm slowly getting the hang of doing.
[Updated on: Wed, 11 December 2002 01:53]
bliz
adel
Re: 4AC compare to 4AFC Wed, 08 January 2003 03:17 Go to previous messageGo to next message
what about the 4a-fc then.......what is the RPM for that?......
laters..
jimmy
zarathos
Re: 4AC compare to 4AFC Wed, 08 January 2003 06:10 Go to previous messageGo to next message
So can you put the 4AFC head on a 4AC bottom end?
urban_myth
Re: 4AC compare to 4AFC Wed, 02 March 2005 07:56 Go to previous messageGo to next message
zarathos wrote on Wed, 08 January 2003 17:10
Yeah, what he said...
urban_myth
Re: 4AC compare to 4AFC Thu, 03 March 2005 09:11 Go to previous messageGo to next message
does anyone know if you can or not?
IRA11Y
Club Member
Re: 4AC compare to 4AFC Thu, 03 March 2005 21:11 Go to previous message
yes you can but you need to change the pistons which will mean selecting a bottom end with the correct size gudgeon pins.
Previous Topic:working out spring rates?
Next Topic:twin carb cold air intake
Current Time: Wed Nov 4 08:01:57 UTC 2026
Total time taken to generate the page: 0.14237403869629 seconds
