Toymods » Tech & Conversions » pop-rivets are they really effective?
Switch to threaded view of this topic Create a new topic
bubbles
Banned user
Liverpool NSW
pop-rivets are they really effective? Wed, 13 July 2005 02:25 Go to next message
In Drift battle issue no 05, Hibinos car has rivets everywhere, does this really reinforce the chassie? Confused
Wouldent it make more sense to plug or spot weld the chassie?
or do you really need any of this(besides a cage)>
Re: pop-rivets are they really effective? Wed, 13 July 2005 02:37 Go to previous messageGo to next message
Sure pop rivets are effective - ask anyone who drives a Land Rover Razz
Danners
Central Coast, NSW
Re: pop-rivets are they really effective? Wed, 13 July 2005 02:45 Go to previous messageGo to next message
they're effective probably because they're so quick to put on, if something breaks off while drifting it can simply be rivetted back on there
Dan
shinybluesteel
melbourne
Re: pop-rivets are they really effective? Wed, 13 July 2005 02:51 Go to previous messageGo to next message
do a thread topic search for seam rivetting, if it doesnt give you any useful info it should give you a laugh.
Re: pop-rivets are they really effective? Wed, 13 July 2005 03:29 Go to previous messageGo to next message
bubbles wrote on Wed, 13 July 2005 12:25
cos it's in dorifto battle, it must be true Wink...
quite a lot of the dorifto crap is just for looks.. afterall, it is about style, not substance..
the wings? air dams etc... cars are not going fast enough to have effective downforce, and going sideways drastically reduces any effect they may have....
but all the cars have wings and fully sik aero bits.... why???
bubbles
Banned user
Liverpool NSW
this has been covered to death Shocked , doh
one last question.
If I plug weld(not on the spot weld, but in the middle of 2 spot welds, drill a holl, mig it in a way that fills the hole up and expands in a way that theres the same amout of penetration on the inside has there is on the outside) wouldent this improve the regidity of the chassie?
I have a felling that it wont.
bubbles
Banned user
Liverpool NSW
Re: pop-rivets are they really effective? Mon, 18 July 2005 06:54 Go to previous messageGo to next message
Found this in clu4ag.com by Moto.P.
A:
It would require: A heavy duty cycle welding machine as it will need a long duration of repeated triggering and welding.
Step 1: remove all interior trim, wire harness, and plastic item which may get damaged with high voltage, and extreme temperatures of melting metal. This is pretty much 'everything' in your interior down to metal floors, dashboards and stripping paint in locations the need welding.
Step 2:
For locations that have to be reinforced through two layers of metal sheets...that's 99% of an AE86 unibody structure. You need to drill holes through one layer for maximum contact and be filled (much resembling appearance and function of riveting)
Step 3:
Welding up these 500~1000 location spots along the body, Functional and Structural analysis should be made to selectively weld and sometimes reinforce the locations where rigidity is needed... That's basically the entire car too... Keiichi's car has 1700 spots and 22 points of structural reinforcements (OK DONT ASK ME WHERE...That would be a book to write...and I would cover some of these in the next article I am preparing along with the recent plans to redo this to my car.)
So yes, if this task seems daunting to you, a professional would gladly (maybe) do this for you... That's about a full week of professional tuner's time...and it is by no means cheap to do properly paying for this by the hour...
In addition, the resulting body will drastically change in structural rigidity that alignment for suspension and spring and valving rates must all be modified to reflect on this and take advantage. It will feel though, better than when it rolled off the factory when it's all said and done.
Or is this better to leave it up to a professional? Is there a local place in Torrance you would recommend? And approximate price range... Yes, it's always better to leave it to a professional if you can't do this properly on your own. Substandard jobs in this area will result in a tweaked car with not many improvements and sometimes for the worse...
Figure on about 40-60 hours of work by a professional to do this correctly and extensively. Multiply that number by whatever your shop will charge by the hour.
Third this is for any person in the forum... does you knowing a place that would weld a stock header in Torrance.
Almost any muffler shops who do custom jobs or projects will fix that extractor header for you... And it would just make it that much cheaper if you can remove it and take it to him so he can work on it immediately.
Spot welding.
I did it on my Eng bay, both door opning, and rear hatch opening.
It will takes time and effort. There is a lot of prep(removing Interior, removing under coating/seal/some paint, removing engine/trans)
If you don't know how to weld, I do not recommend this.
Re: pop-rivets are they really effective? Sat, 20 August 2005 07:41 Go to previous messageGo to next message
BWAHAHAHAHHAHHAHAHHAHAHHA Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing
Re: pop-rivets are they really effective? Sat, 20 August 2005 08:06 Go to previous messageGo to next message
http://www.materials.unsw.edu.au/~sford/omfgretard9sf.jpg
kingmick
Banned by his request
moved to tamworth
Re: pop-rivets are they really effective? Sat, 20 August 2005 08:39 Go to previous messageGo to next message
i used to go out with bubbles until he turned me into the fully sic drifto battle chick.now im just a strong women hear me roar!
http://www.iranian.ws/gallery/albums/my_downloads/Funny%20Pics/crazyface.jpg
STR8 2.8
Re: pop-rivets are they really effective? Sat, 20 August 2005 13:46 Go to previous messageGo to next message
for gods sake...its spelt chassis, not chassie
Wezelton
Sunshine Coast
Re: pop-rivets are they really effective? Tue, 23 August 2005 12:08 Go to previous messageGo to next message
I was thinkin of seam welding some areas in my car. My friend who's a full time welder think the best thing to do would be to strip back interia paint ect. and just do sections at a time, say 30cm long. Just so you dont stress n stretch the body too much, even jsut having too much heat on one side can worp the car nicely. Anyone on here a good welder ? give us your input on the idea!
rollin_stock
February 2005
Re: pop-rivets are they really effective? Tue, 23 August 2005 12:25 Go to previous messageGo to next message
Wezelton wrote on Tue, 23 August 2005 21:38
jesus, 30cm long? thats way too much, 25mm is what i was told, then leave a 25mm gap, then go again. And the person who said this is georgeos, a bloke who used to prepare the stanzas for portugese datsun rally team, this is something that should not be done without hours of research and then hundreds upon hundreds of hours on the job itself. Infact i would say you should not do it. All this work then youre just going to hoegey it into the first tyre wall you see anyway.
Re: pop-rivets are they really effective? Tue, 23 August 2005 13:30 Go to previous messageGo to next message
rollin_stock wrote on Tue, 23 August 2005 22:25
Wezelton
Sunshine Coast
Re: pop-rivets are they really effective? Wed, 24 August 2005 04:41 Go to previous messageGo to next message
I meant to say 30mm Embarassed Was just typing too fast and heavily involved in msn lol Maybe i'll ask an engineering place n see what they have to say about it..
Wes.
Anyone recon pop rivets are the go ? haha would look funny
Re: pop-rivets are they really effective? Wed, 24 August 2005 06:15 Go to previous messageGo to next message
like this??
http://www.materials.unsw.edu.au/~sford/bubbles1.jpg
kingmick
moved to tamworth
Re: pop-rivets are they really effective? Wed, 24 August 2005 06:29 Go to previous messageGo to next message
its performance would be riverting!lmao
mick
Corona RT142
Campbelltown
Re: pop-rivets are they really effective? Wed, 24 August 2005 06:31 Go to previous messageGo to next message
kingmick wrote on Wed, 24 August 2005 16:29
mick
bwhahhahaahaha lamest joke evah, oldcorollas you've really got mileage out of that chop haven't you.
Re: pop-rivets are they really effective? Wed, 24 August 2005 06:45 Go to previous message
meh, only second time posted.. i like it tho Smile
i forgot to do the windscreen speed holes tho...
Previous Topic:Warning light for tail light
Next Topic:++ 1J Hydrolic fan Help Needed ++
Current Time: Fri Nov 20 18:26:18 UTC 2026
Total time taken to generate the page: 0.0078208446502686 seconds
