Toymods » Tech & Conversions » Need help with alternator on GZE
hutchiroku
Central Coast
Need help with alternator on GZE Wed, 13 July 2005 03:57 Go to next message
I have a gze sprinter and the alternator it seems has stopped working. I think this is what happened because my volt gauge was on 10 when i started car then dropped to zero when i drove it. 500m later the car stopped and completly dead battery. the battery is a new century so it cant be that. I think the problem is that when the conversion was done the guy has not lined the alt up with the crank so i'd imagine it would stuff the bearing or something.
So has anyone had this problem with it not lining up?
Is it a dead alternator or something else?
Any advice much appreciated
hutchiroku
Central Coast
Re: Need help with alternator on GZE Wed, 13 July 2005 04:11 Go to previous messageGo to next message
Here are some pics of the problem?
http://img326.imageshack.us/img326/8131/alt10rh.th.jpg
http://img326.imageshack.us/img326/598/alt22og.th.jpg
http://img326.imageshack.us/img326/4839/alt36cm.th.jpg
feral4mr2
Bundaberg, Qld.
Re: Need help with alternator on GZE Wed, 13 July 2005 13:03 Go to previous messageGo to next message
checking that all the plugs are connected properly is a start, make sure all fuses and the fuseable link is fine.
when my gze alt stuffed up i bought a universal 120amp bosch alternator, much better. Smile
hutchiroku
Central Coast
Re: Need help with alternator on GZE Thu, 14 July 2005 00:41 Go to previous messageGo to next message
Hey im pretty sure it has something to do with alt cause it did start and drive fine just died after a couple of minutes of driving. Dont spose you know the part number of that alt/ cost and if it line up prop on gze??
Cheers mate
Re: Need help with alternator on GZE Thu, 14 July 2005 07:10 Go to previous message
i see a couple of problems here...
The Witzl Sez:
1/ Go and get the PROPER ancillary belt configuration for a 4a-gze... what's been done there is a complete FUCKUP. The alternator is being held on by the bottom swivel bolt and the belt only!!!! You should have the air con compressor there, and the belt going from crank to aircon to alt to idler/tensioner pulley to crank.... lucky for you i have this equipment, at a price. Smiley =
2/ Judging by the installation of that alternator - it's wired like arse. The alternator won't charge if the charge light isnt wired up... nor if the fuse/fusible link is blown.
3/ Dont even THINK about asking for a toyota genuine part, unless you like having a bleeding arse. Shocked
Here is how the alt SHOULD be mounted.... ignoring the MSpaint style drawing on the pic, you can see how the belt on the exhaust side goes arount the air con compressor AND the alternator, very much unlike your setup!!
AND HOLY FUCK I JUST SAW THAT THE IDLER PULLEY IS BEING USED LIKE A FIXED RIBBED PULLEY!!!!!!!!!!!!!!!!!!!!
Dude, if you are in sydney - contact me.
http://www.rollamods.com/witzl/GZE/turbo-ancillaries.jpg
[Updated on: Thu, 14 July 2005 07:11]
Previous Topic:Buying Mags, just where from ???
Next Topic:whats required 4agze in ke20?
Current Time: Sat Oct 17 22:34:36 UTC 2026
Total time taken to generate the page: 0.0054240226745605 seconds
