Toymods » Tech & Conversions » Gearbox leak from speedo plug -> overfilling?
RobST162
Gearbox leak from speedo plug -> overfilling? Wed, 13 July 2005 04:28 Go to next message
ok, this has been an issue that has been irritating me for some time now and it's time to put it to rest Smile
Installed the new g-box a while back.
Filled it till oil started running out of the fill hole (car is level).
Drive.
Starts leaking from speedo plug
Get worried, install new o-ring on speedo.
Fill g-box till oil starts running out of fill hole (level car), re-insert plug.
Still leaks!
Get worried I might risk damage to my box.
Today:
Jack car up level after leakage for a month or so.
Confirm oil mess around speedo plug and oil mess on pipes etc etc in there everywhere
Take fill plug out and insert little finger.
Lo and behold, oil on my finger.
Raise back of car 3cm or so. Oil comes out of fill hole.
How is this possible!? After leakage and all.
I conclude that I had overfilled the box using the oil pump (manual) and the speedo plug was the weakest link for an overfull gearbox, so oil was forced out.
However, even if it WAS too full, why would it have leaked? Oil doesn't increase in size with heat.. so??
And now, I am worried that it may not actually be correctly full, and i might damage my box, but reading point 5 from today makes me think that it HAS to be correct.
*proceeds to pull hair out*
*remembers that he shaves his head*
*posts on toymods*
Smile
[Updated on: Wed, 13 July 2005 06:00]
RobST162
Re: Gearbox leak from speedo plug -> overfilling? Wed, 13 July 2005 05:31 Go to previous messageGo to next message
maybe it's driveshaft seals leaking??? I didn't think of that
ok, spent 10 minutes lying under my car watching everything while it was in gear
nothing is leaking! grr
Rob
Re: Gearbox leak from speedo plug -> overfilling? Wed, 13 July 2005 05:45 Go to previous messageGo to next message
A little leak can create A LOT of mess.
We've had the speedo cable leak before, just needed to screw it in a bit tighter.
Not to familiar with FWD boxes, so thats all the help I can offer.
Mr DOHC
Re: Gearbox leak from speedo plug -> overfilling? Wed, 13 July 2005 07:49 Go to previous messageGo to next message
RobST162 wrote on Wed, 13 July 2005 15:31
are you nuts Shocked
RobST162
Re: Gearbox leak from speedo plug -> overfilling? Wed, 13 July 2005 08:14 Go to previous messageGo to next message
Mr DOHC wrote on Wed, 13 July 2005 17:49
heheh Laughing yeah that does read funny hey.
It was on jack stands Wink
Meat_rack
East Maitland NSW
Re: Gearbox leak from speedo plug -> overfilling? Wed, 13 July 2005 08:46 Go to previous messageGo to next message
What kind of box is it?
RobST162
Re: Gearbox leak from speedo plug -> overfilling? Wed, 13 July 2005 08:50 Go to previous messageGo to next message
hey meat Smile
I don't know it's number, it's from a 1998 ST202 running a BEAMS setup.. so it's an LSD.
I guess the leak must be really minor. There was quite a lot of oil distributed around the pipes and hoses in the area.
well, more like a big mess than a lot of oil Wink thanks CrUZsida
I am wondering if there is a small leak in the rhs driveshaft seal? I couldn't see any leakage from plug while it was turning over.. and I am guessing that in any case the speedo plug wouldn't really spurt as much as dribble.. but even if it did that, and then made it's way to the drive shaft it would get flicked around.. so grr Wink
[Updated on: Wed, 13 July 2005 08:55]
Meat_rack
East Maitland NSW
Re: Gearbox leak from speedo plug -> overfilling? Wed, 13 July 2005 09:02 Go to previous messageGo to next message
Well you would be supprised speedo seals have a tendancy to piss out oil for some strange reason. Does the plug have a washer on it. If so did you replace it when you re-fitter it?
Andrew..
warrior
Sydney / NSW
Re: Gearbox leak from speedo plug -> overfilling? Wed, 13 July 2005 09:13 Go to previous messageGo to next message
hey Rob,
there is a rubber inside the short speedo cable, have you made sure its still there or hasnt eroded, heres a pic of it. Smile
http://img78.photobucket.com/albums/v293/warrior007/rubber.jpg
RobST162
Re: Gearbox leak from speedo plug -> overfilling? Wed, 13 July 2005 09:15 Go to previous message
oh that's a good call I didn't think of looking at that one!
The 0-ring on the shaft into the hole is brand spanker so i was scratching my head..
thanks bro Smile
Ok, I will inspect that tomorrow morning! Smile
Previous Topic:ae92 bellhousing to crossmember engine mount....
Next Topic:How to fit Driving and Fog Light to a 1991 SX Seca 5 speed
Current Time: Fri Nov 20 21:10:32 UTC 2026
Total time taken to generate the page: 0.0045030117034912 seconds
