Toymods » Tech & Conversions » LSD Gear Oil
trevtrev
LSD Gear Oil Wed, 13 July 2005 05:36 Go to next message
Erm Embarassed What will happen if someone uses Non LSD gear oil in an LSD Box?
Do I need a new mechanic?
Talking about an AE101 4age
Re: LSD Gear Oil Wed, 13 July 2005 05:43 Go to previous messageGo to next message
Did the mechanic know it was LSD?
Just drain the oil and fill with LSD oil.
If its only been a short while no damage should have been done.
trevtrev
Re: LSD Gear Oil Wed, 13 July 2005 05:48 Go to previous messageGo to next message
Mechanic says he did not realise it was LSD (the build plate from the half cut has the LSD code). It has been 4 months and 12000km. Would it be like closing the gate after the horse has bolted to do it now?
Re: LSD Gear Oil Wed, 13 July 2005 05:50 Go to previous messageGo to next message
By changing to LSD oil you will hopefully prevent any further damage.
Doesn't mean you haven't done any yet though.
I'm not a diff expert, so I can't really say.
Re: LSD Gear Oil Wed, 13 July 2005 06:21 Go to previous messageGo to next message
I don't think using non-LSD oil causes any damage, it just lacks the friction modifiers which help the clutch packs do their job. In other words, your LSD hasn't been working as well as it should with the wrong oil in it. Put in the correct oil and all will be well again.
trevtrev
Re: LSD Gear Oil Wed, 13 July 2005 06:40 Go to previous messageGo to next message
Thanks Norbie. I like the sound of that.
Trev
Toobs
Re: LSD Gear Oil Wed, 13 July 2005 06:52 Go to previous messageGo to next message
Depends what sort of LSD it is... a Torsen LSD won't mind, a clutch type LSD will slip and chatter.
Most Torsens should be fed API GL-5 75W/90
Most clutch type LSD's should be fed an API GL-5 LS90
Most gearbox's and slip diffs can be fed API GL-5 75W/90 too which is a bonus for those with a torsen LSD or 3.
trevtrev
Re: LSD Gear Oil Wed, 13 July 2005 07:16 Go to previous message
Hmm, An AE92 with 3 Torsens? Bring it on.
No, mine's a factory one from my Silvertop Halfcut.
Trev
Previous Topic:ra23 rear window rollers
Next Topic:turbo resting on the firewall
Current Time: Fri Oct 30 04:05:43 UTC 2026
Total time taken to generate the page: 0.030717134475708 seconds
