Toymods » Tech & Conversions » boost conts that allow diferent setting with each gear
Mr DOHC
boost conts that allow diferent setting with each gear Wed, 13 July 2005 07:45 Go to next message
my mate has a 2002 Turbo Astra SRi.
he wants a boost controller that can change the boost level with each gear, i.e. 5 for 1st 10 for 2nd and 15 for 3/4/5
does anyone know who does these
off-road
Alice Springs
Re: boost conts that allow diferent setting with each gear Wed, 13 July 2005 08:09 Go to previous messageGo to next message
I would think that the only way it could be done is with a sophisticated after market ECU (Autronic or Motec and possibly others) that allow for connection of wheel speed sensors.
Mr DOHC
Re: boost conts that allow diferent setting with each gear Wed, 13 July 2005 10:05 Go to previous messageGo to next message
i know there is a way to do it with a detent basic switch on the gearstick, it was in an old fast/hit/rice fours magazine.
just wondering what system can use that
Re: boost conts that allow diferent setting with each gear Wed, 13 July 2005 10:12 Go to previous messageGo to next message
i believe some of the current ones allow programming of boost vs rpm, TPS and gear selected..
http://www.superstreetonline.com/techarticles/3948 3/links here, but they are not the latest greatest ones....
BlackSupra
Re: boost conts that allow diferent setting with each gear Wed, 13 July 2005 10:17 Go to previous messageGo to next message
I have an Apexi AVCR, im pretty sure you can set boost in gear.
Apparently the unit can learn gears based on rpm, throttle and speed sensor input.
Mr DOHC
Re: boost conts that allow diferent setting with each gear Wed, 13 July 2005 10:20 Go to previous messageGo to next message
so its a job for the pros to put in, bear in mind we are fairly technically minded
BlackSupra
Re: boost conts that allow diferent setting with each gear Wed, 13 July 2005 10:25 Go to previous messageGo to next message
Witzl and i wired mine up
i mean, they give you the pins to tap into if its a jap ecu.
But you need:
-Ignition
-RPM
-TPS
-Speed signal
-Ground
-Ground
http://www.apexi-usa.com/pdfWiring/8.pdf
They aren't cheap though.
Mr DOHC
Re: boost conts that allow diferent setting with each gear Wed, 13 July 2005 10:40 Go to previous messageGo to next message
what do u call expensive
what wholesalers bring that stuff in, i wanna know if we have an account with any of them
BlackSupra
Re: boost conts that allow diferent setting with each gear Wed, 13 July 2005 12:08 Go to previous message
i call $900 expensive Shocked
Previous Topic:how much power will my soarer gearbox handle???????????
Next Topic:7MGTE bore size?
Current Time: Fri Nov 20 20:17:33 UTC 2026
Total time taken to generate the page: 0.0062949657440186 seconds
