Toymods » Tech & Conversions » Increasing the boost on a 1GGTE
scotthRA40
Melton, Vic
Increasing the boost on a 1GGTE Wed, 11 December 2002 00:22 Go to next message
Can some please help me with this topic, i know that the 1GGTE come with 11 psi, how can i increase this? and how much too?
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: Increasing the boost on a 1GGTE Wed, 11 December 2002 00:36 Go to previous messageGo to next message
Bleed off valve.
14psi.
Very Happy
scotthRA40
Melton, Vic
Re: Increasing the boost on a 1GGTE Wed, 11 December 2002 00:37 Go to previous messageGo to next message
Excatly how is this done
Nark
Cabramatta, NSW
Re: Increasing the boost on a 1GGTE Wed, 11 December 2002 01:59 Go to previous messageGo to next message
Do a search.
http://www.toymods.org.au/msgboard/index.php?t=sea rch
There should be plenty of information on fitting bleed off valves or boost controllers...
There should also be plenty of info floating around the internet.
Basically, you put a T-pipe in the line that opens up the wastegate. Fooling the wastegate into thinking that there's less boost than there actually is so that it stays shut until the required boost level.
Hope I'm making sense.
Dabbid
Yowie Bay, Sydney
Re: Increasing the boost on a 1GGTE Wed, 11 December 2002 08:47 Go to previous messageGo to next message
ok, just blew 2 turbos Sad
how much boost should these thingsa handle??
for everyone that wants to know, they didnt like 18psi
although i thought it was pretty good, lol
u can call me a dickhead, but i did it knowing i had a spare set...
CrAiGzEE
south of the big smoke
Re: Increasing the boost on a 1GGTE Wed, 11 December 2002 12:30 Go to previous messageGo to next message
nark got any picture?
Bugman
Re: Increasing the boost on a 1GGTE Wed, 11 December 2002 12:32 Go to previous messageGo to next message
18psi.. the little fellas would have been screaming.
Smiley =
Nark
Cabramatta, NSW
Re: Increasing the boost on a 1GGTE Wed, 11 December 2002 22:46 Go to previous messageGo to next message
Oz_Craig, sorry dude. No pix, but I'm sure there are plenty on the internet.
Dabbid, from memory, the stock turbos are pretty suspect after 14psi and the sane limit is considered 16psi...
Re: Increasing the boost on a 1GGTE Thu, 12 December 2002 00:29 Go to previous messageGo to next message
Wonder how the Blitz babies will cope with some excess boost Razz
TRACTION_ISSUES
Re: Increasing the boost on a 1GGTE Thu, 12 December 2002 04:33 Go to previous messageGo to next message
14.5psi al day, everyday for 2 years...never missed a beat......and the turbos had NO oil in them when i pulled them off
Re: Increasing the boost on a 1GGTE Thu, 12 December 2002 04:37 Go to previous messageGo to next message
Hey dude, just read your signature.
What are you doing to your 1GGTE to get 300kW?
Bugman
Re: Increasing the boost on a 1GGTE Thu, 12 December 2002 05:02 Go to previous messageGo to next message
what isnt he doing would be a better question!
gold28
Madrid - Spain
Re: Increasing the boost on a 1GGTE Thu, 12 December 2002 05:52 Go to previous messageGo to next message
Hey fellas, are you putting a separate bleed on each turbo or are you t'ing the wastegate actuators together and using only one bleed??
CrAiGzEE
Re: Increasing the boost on a 1GGTE Thu, 12 December 2002 12:17 Go to previous messageGo to next message
i did a search cant find anything
boo Sad
Nark
Cabramatta, NSW
Re: Increasing the boost on a 1GGTE Fri, 13 December 2002 01:03 Go to previous messageGo to next message
Did a quick search. Try these:
http://home.att.net/~jason510/ManualController.htm
http://chrislow.com/bleedvalve.html
http://www.xmission.com/~dempsey/perform/instruct. htm
http://www.rx7turboturbo.com/robrobinette/boost_no te.htm
http://www.pacarsearch.com/stealth/boostcontroller .htm
http://www.xmission.com/~dempsey/perform/2stgnosp. htm
http://www.lotuselan.com/boost_controller.html
Heaps more out there if but that should do...
TRACTION_ISSUES
Re: Increasing the boost on a 1GGTE Fri, 13 December 2002 02:36 Go to previous messageGo to next message
Frank,
All will be revealed in a few weeks my friend Very Happy
Re: Increasing the boost on a 1GGTE Fri, 13 December 2002 06:58 Go to previous messageGo to next message
I await eagerly my friend Razz
jza70-mel
Perth WA
Re: Increasing the boost on a 1GGTE Sat, 14 December 2002 08:43 Go to previous messageGo to next message
I too look forward to the mods and see if any can be applied to the mighty 1JZ!
TRACTION_ISSUES
Re: Increasing the boost on a 1GGTE Sat, 14 December 2002 21:42 Go to previous messageGo to next message
OK,
1) There is only a poofteenth of room left with the new turbos and manifold Twisted Evil
2) The i/c doesnt fit between the headlights (fuggit!!) Mad
3) The ECU is worth $3500 Confused
4) mmmmmm......traction control Very Happy
PayneyCelica18rg
Southport
Re: Increasing the boost on a 1GGTE Sun, 15 December 2002 00:26 Go to previous messageGo to next message
yes 300kW 1g-gte. I too would like to see several piccies when its done... how the hell will you keep the bugger from wheel spinnig, you'd need duel wheels, and a lockable diff... MAD...
Bugman
Re: Increasing the boost on a 1GGTE Sun, 15 December 2002 05:51 Go to previous messageGo to next message
here's a pic of a bleeder valve installed.
hope it's ok to post a pic of the old setup phil
http://members.optushome.com.au/1977celica/Conversion/Half-Cut/enginedside.JPG
Bugman
Re: Increasing the boost on a 1GGTE Sun, 15 December 2002 05:52 Go to previous messageGo to next message
you can see it it's the bright blue valve above the turbo down near the air filter
TRACTION_ISSUES
Re: Increasing the boost on a 1GGTE Sun, 15 December 2002 07:12 Go to previous messageGo to next message
Damn, trhats scary...cant remember it being like that now Laughing
CrAiGzEE
Re: Increasing the boost on a 1GGTE Sun, 15 December 2002 10:23 Go to previous messageGo to next message
thanks luke!
looks like you have ditched the powersteering too!!
Bugman
Re: Increasing the boost on a 1GGTE Sun, 15 December 2002 10:28 Go to previous message
thats phils motor.. well old 1g Smiley =
but why wouldnt you ditch it? it's one more thing slowing the motor down plus power steering is for girls Smiley =
Previous Topic:Koni vs KYB
Next Topic:18RGU cams
Current Time: Wed Oct 28 05:44:26 UTC 2026
Total time taken to generate the page: 0.013674974441528 seconds
