Toymods » General Car Talk » Wheel Alignment settings... what you think?
darayzins
July 2005
Wheel Alignment settings... what you think? Wed, 13 July 2005 08:08 Go to next message
My car has aroun 2 degrees negative camber on the back. This is the least amount of camber they can adjust the wheels to cause my car has been lowered a bit. To compensate for inner tyre wear the guys that did my wheel alignment for me said they put extra toe in/out so that the tyres would wear out evenly.
What you guys think of this...
Shouldn't they just keep the wheels straight... and then when the inner side of the tyres start look like they are getting bad I just rotate the tyres (swap the tyres/rims)
Or is what they are doing sounding more logical?
Thanks in advance..
September_Squall
Melbourne, Australia
March 2005
Re: Wheel Alignment settings... what you think? Wed, 13 July 2005 10:05 Go to previous message
What they are suggesting is a bandaid solution to your rooted suspension geometry.
What you're suggesting is an even more bandaid solution, especially if you've got assymetrical tyres.
I guess there's two options:
1> Short term cost, long term gain: Get a rear camber fix to correct your alignment. Reap the long term rewards.
2> Long term cost, no gain at all: Replace the rear tyres every x/2 kilometers (where x represents typical tyre wear rate).
Previous Topic:Lexus LS400
Next Topic:suspension
Current Time: Wed Oct 28 18:02:10 UTC 2026
Total time taken to generate the page: 0.019980907440186 seconds
