Toymods » Tech & Conversions » (Fixed) I can hear my starter solenoid, but it doesn't kick
davedave
(Fixed) I can hear my starter solenoid, but it doesn't kick Wed, 13 July 2005 23:02 Go to next message
Well I'm pretty much finished the wiring of my 3sgte-aw11 swap and I was finally to the stage yesterday of turning the key.
But all I got was a 'tick' from the starter.
Now, as I understand a starter, there really is only one electrical loop that needs to be completed for it to go. This circuit which is also hooked up to the cold start gear.
So hearing the solenoid kick in but not going, can I safely say that my starter is knackered?
Dave
[Updated on: Fri, 15 July 2005 09:07]
Re: I can hear my starter solenoid, but it doesn't kick Wed, 13 July 2005 23:12 Go to previous messageGo to next message
Can you attach a good size bit of wire to the positive of the battery and then touch the other end to the starter solenoid?
davedave
Re: I can hear my starter solenoid, but it doesn't kick Wed, 13 July 2005 23:21 Go to previous messageGo to next message
This one goes from my battery in the frunk, directly to the post on the starter that the alternator etc join to.
http://mr2.scattered.com.au/image.php/size/150/image/IMGP1735.JPG
trdcmy
West Sydney
July 2005
icon4.gif  Re: I can hear my starter solenoid, but it doesn't kick Wed, 13 July 2005 23:27 Go to previous messageGo to next message
Hey bro i had the same thing happen with my car it still sometimes doesnt start, do you have a starter relay cause if you dont like me it will do that, you can try hitting the solenoid while another person trys to start it that works for me, but yea check if you have a starter relay Very Happy
Re: I can hear my starter solenoid, but it doesn't kick Wed, 13 July 2005 23:32 Go to previous messageGo to next message
What I want you to do Dave is apply a good reliable source of +v to the starter solenoid. This will prove something.
davedave
Re: I can hear my starter solenoid, but it doesn't kick Wed, 13 July 2005 23:55 Go to previous messageGo to next message
Just so I'm sure, the starter solenoid is inside the starter, right? And the only connections on a starter are a positive and negative.
Below is how my modified circuitry works, I hope.
http://mr2.scattered.com.au/image.php/size/800/image/other///starting.jpg
RAV-GT4
Toymods member
Rydalmere, NSW
Re: I can hear my starter solenoid, but it doesn't kick Thu, 14 July 2005 00:02 Go to previous messageGo to next message
Just my opinion here Dave, but if I hear the starter solenoid click when I turn the key, the first thing I think of is a flat battery. Have you tried another battery or power source? Do you get interior lights?
Let us know how it goes mate, I'd like to see it finished. Wink Is it still in the Shire or has it moved?
davedave
Re: I can hear my starter solenoid, but it doesn't kick Thu, 14 July 2005 00:05 Go to previous messageGo to next message
Brand spanking new sealed higher CCA (360) battery, bought yesterday. Get's 12.45 Volts accross the terminals.
It's not the battery pictured above.
Yep, still in the shire. Hopefully will be giving it a blast soon, I'll let you know Smiley =
Re: I can hear my starter solenoid, but it doesn't kick Thu, 14 July 2005 00:07 Go to previous messageGo to next message
The solenoid is on the side of the starter.
There will be one big fat cable from the starter going directly to the positive terminal on the battery. There will be then another smaller wire which is the "start" wire. If possible remove this smaller wire and apply +V to the now vacant terminal on the starter. This will hopefully make the engine turn over.
The ground connection for the starter is made through the engine block. So also make sure your engine have some good earth cables going to it.
davedave
Re: I can hear my starter solenoid, but it doesn't kick Thu, 14 July 2005 01:21 Go to previous messageGo to next message
I think you might have found the winner there Shane.
It makes sense that I can hear the solenoid click when it gets power, but there's no earth to power the sucker.
I do have a big cable from the gearbox to the strut tower though.
I'll head over now and just strap a crap load more earth straps to it and see how I go.
Thanks!
Re: I can hear my starter solenoid, but it doesn't kick Thu, 14 July 2005 01:52 Go to previous messageGo to next message
If you get stuck, give me a call and i'll see if I can talk you through some shit. 0414386575
davedave
Re: I can hear my starter solenoid, but it doesn't kick Thu, 14 July 2005 02:04 Go to previous messageGo to next message
Thanks heaps.
I'm heading over to work on it now. I'd love to hear it fire up today!
Re: I can hear my starter solenoid, but it doesn't kick Thu, 14 July 2005 02:28 Go to previous messageGo to next message
Are you using a starter relay like in the diagram?
davedave
Re: I can hear my starter solenoid, but it doesn't kick Thu, 14 July 2005 03:17 Go to previous messageGo to next message
Sure do.
I've intercepted the wire that comes from the E(starter) connector on the 3SGTE loom and wired it to Pin 4 on the AW11 M2 connector. Ran a wire directly from the battery in the frunk to the post where the D(starter) connector hooks up. And wired the D(starter) connector on the 3SGTE loom to Pin 1 on the AW11 M2 connector.
I'm here with the car now and it all seems cool bananas.
The starter is getting 12.38 volts from the battery (tested from the post where it's hooked up to a ground point). I'm using welding cable, so I think it should be fine over the 3 metres of cable.
I've ran a test over a few points on the engine (including some bolts on the starter) and they all have continuity to earth.
*shrug* I've got NFI
Re: I can hear my starter solenoid, but it doesn't kick Thu, 14 July 2005 03:22 Go to previous messageGo to next message
Keep the voltmeter on the starter where you read 12.4x volts
Then get someone to turn the key.
Does it drop?
If so, you have shite earths.
When I put my battery in the boot, I had 2 4gauge earths from the -ve terminal to the body, and 2 4gauge earths from the block to the chassis.
Also, welding cable is not the best product to use.
It can have very high resistance.
davedave
Re: I can hear my starter solenoid, but it doesn't kick Thu, 14 July 2005 05:10 Go to previous messageGo to next message
Thanks heaps for all of the advice fellas!!!!
It ended up being the starter was rooted. I pulled it off and took it around the corner and had an auto electrician put it on the test bench. He's going to pull it apart this arvo and try and fix it, so hopefully I'll fire up the beast after that.
Very nice cressy out the front of the electrics place too, I'll have to ask him what's in it. None of the cars were standard in the place, so I'm guessing it will be something decent.
davedave
Re: I can hear my starter solenoid, but it doesn't kick Thu, 14 July 2005 05:12 Go to previous messageGo to next message
CrUZsida wrote on Thu, 14 July 2005 13:22
Does it drop?
It went from 12.38 down to 11.5 - is that ok?
Re: (Fixed) I can hear my starter solenoid, but it doesn't kick Thu, 14 July 2005 05:19 Go to previous messageGo to next message
11.5 should be acceptable yes.
berad
Re: (Fixed) I can hear my starter solenoid, but it doesn't kick Thu, 14 July 2005 05:20 Go to previous messageGo to next message
relay will be what u want it connects to the ignition wire not the main battery one im sure its been stated...
davedave
Re: (Fixed) I can hear my starter solenoid, but it doesn't kick Thu, 14 July 2005 07:33 Go to previous messageGo to next message
Yep, have relay, will travel. The pic above is almost exactly my AW11 wiring, exept for the cold start stuff which is now in 3SGTE loom land.
Got the starter back with a few things inside fixed. I'd over tightened the gear on the positive terminal and in turn rotated the base of it which shorted inside, whoops.
I now have a weird intermittant problem where the wire going to Pin 1 on the M2 connector (pictured above, but pictured much better below) is earthing somewhere. It's got me f*cked where and why it's intermittant (sucks to find), but I'll be persisting with it tonight.
http://mr2.scattered.com.au/image.php/size/800/image/other///power_small.jpg
Again, thanks all for your help. Problem solved and on to the next one Wink
davedave
Re: (Fixed) I can hear my starter solenoid, but it doesn't kick Thu, 14 July 2005 08:06 Go to previous messageGo to next message
Well after a bit of investigation I have found that when I turn the ignition to 'on', the whole circuit connected to Pin 1 on the M2 becomes earthed Confused
I have disconnected all of my wiring interfacing with the AW11 body loom, so nothing I have done should be affecting this.
It doesn't seem right though, wouldn't this just blow a fuse immediately?
davedave
Re: (Fixed) I can hear my starter solenoid, but it doesn't kick Thu, 14 July 2005 11:48 Go to previous messageGo to next message
Anyone?
davedave
Re: (Fixed) I can hear my starter solenoid, but it doesn't kick Fri, 15 July 2005 09:06 Go to previous messageGo to next message
Sorted, wasn't really a problem after all Cool
The starter's going now, circuit relay is opening up and fuel is ruching around, just no go go. Will be back there on Monday to try and make some 3SGTE magic happen Wink
V8_MA61
Re: (Fixed) I can hear my starter solenoid, but it doesn't kick Fri, 15 July 2005 10:18 Go to previous message
i have the same problem on my ma70 with 7mge.
i dont know whether mine is lack of power, bad earth of what...god knows...
[Updated on: Fri, 15 July 2005 10:20]
Previous Topic:quick microtech Q
Next Topic:late model wheels
Current Time: Thu Nov 19 07:29:24 UTC 2026
Total time taken to generate the page: 0.007133960723877 seconds
