Toymods » Tech & Conversions » Turbos: diff btw CT20b and CT26?
tangcla
  www.tangcla.com
Turbos: diff btw CT20b and CT26? Thu, 14 July 2005 08:37 Go to next message
I recently bought an ST205 GT-Four, and to my knowledge, it should come with a CT20B, right...?
well, I'm not sure if the turbo I have is a CT20 or CT26, because some people have told me the ST205 comes with a CT26... so what's the difference between CT20 and CT26?
Also, any outward differences so I can spot it straight away? I can't see CT2x on the housing anywhere...
davedave
Re: Turbos: diff btw CT20b and CT26? Thu, 14 July 2005 08:49 Go to previous messageGo to next message
If it just says Toyota on the housing, it's a CT20B. CT26's have it written on it after the word Toyota.
Not sure of how much it differs to the CT26, but it's a wanted item. I could be talking out of my arse, but I thought the main difference is that it flows better up top (doesn't run out of puff as quickly as the CT26) and also spools up a little quicker.
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Turbos: diff btw CT20b and CT26? Thu, 14 July 2005 10:48 Go to previous messageGo to next message
I got an ST205 front-cut from Japan, and the turbo said Toyota, that's it. It was later found to be a CT20b when the turbo had to be rebuilt. The compressor wheel is ceramic and spins up straight off idle, very responsive. Because my turbo's seals were stuffed, I had mine rebuilt with the guts of a CT26 and the compressor wheel upped to a 56-trim (hi-flowed). Takes a little longer to get off the mark than the CT20b, but it's better mid-range and top end.
If I could have kept the standard turbo, I would have. Confused
Re: Turbos: diff btw CT20b and CT26? Thu, 14 July 2005 11:00 Go to previous messageGo to next message
did toyota actually call it a CT20B, after eading up a few things, toysport seems adamant that there is no CT20B except for the racing turbo from many years ago (2TGTE time), and that the later 3SGTE turbos are still CT26, just revised versions.. but not a CT20B... it's all semantics Wink
Re: Turbos: diff btw CT20b and CT26? Thu, 14 July 2005 11:11 Go to previous messageGo to next message
The ST205 only comes with a twin entry CT20B.
davedave
Re: Turbos: diff btw CT20b and CT26? Thu, 14 July 2005 21:36 Go to previous messageGo to next message
oldcorollas wrote on Thu, 14 July 2005 21:00
You are exactly right oldcorollas, there's no such thing as a CT20B. It was a term invented on the internet. But since everyone knows it as that it's far easy to keep using the term rather than saying a CT26 off a gen3 3SGTE Wink
Re: Turbos: diff btw CT20b and CT26? Thu, 14 July 2005 21:43 Go to previous messageGo to next message
The name CT20B came from Toyota. It is used in the Service manual and in the EPC.
I would also have to wonder why they would call it a CT26 when its a different size turbo.
I could understand calling it a CT26 if the housings were the same size but just using a ceramic turbine and better bushes.
styler
Re: Turbos: diff btw CT20b and CT26? Thu, 14 July 2005 22:52 Go to previous messageGo to next message
i was under the impression it was named by toyota, it is quite different to ct26 which i suppose also has its own variants - single/twin entry, ceramic/steel, different compressor sizes.
davedave
Re: Turbos: diff btw CT20b and CT26? Thu, 14 July 2005 23:00 Go to previous messageGo to next message
Cool1: Where abouts does it make make mention of CT20B in the EPC. The most I can get out of it is the part number 17201-74070
Edit: Also, just checked the enging manual here http://www.celicatech.com/imagearchive/bgbonline/b gb.php and it says nothing of the sort either.
I need proof dammit Wink
[Updated on: Thu, 14 July 2005 23:08]
The CT20B i have is steel wheel.. Not sure what its from though.
davedave
I could be wrong, but maybe Aussie delivered ST205
Re: Turbos: diff btw CT20b and CT26? Thu, 14 July 2005 23:05 Go to previous messageGo to next message
davedave wrote on Fri, 15 July 2005 09:00
The EPC gives the description of CT20B/something/something
I think one of the somethings describes the actuator location.
davedave
Re: Turbos: diff btw CT20b and CT26? Thu, 14 July 2005 23:17 Go to previous messageGo to next message
Just did a search of the EPC on a ST205 for CT26 - nothing, CT20B - nothing, CT20 - nothing, TURBO - went through every diagram and nonthing mentions CT20B or CT26, ACTUATOR - same thing.
*shrug* I don't really care, but it would be nice to put this ancient arguement to rest.
tangcla
  www.tangcla.com
Re: Turbos: diff btw CT20b and CT26? Fri, 15 July 2005 00:26 Go to previous messageGo to next message
hey thanks guys. I thought the CT20 was supposed to be steel wheel....?
I'm lost Razz
Re: Turbos: diff btw CT20b and CT26? Fri, 15 July 2005 00:33 Go to previous messageGo to next message
CT20 = steel
CT20A = ceramic
CT20B = ceramic
Note that all three are very different turbos, despite the similar name.
Joshstix
Toymods Vice President
Re: Turbos: diff btw CT20b and CT26? Fri, 15 July 2005 01:16 Go to previous message
The export market ST-205 CT20b's were also steel wheeled.
Previous Topic:AE86 Large vs small axles
Next Topic:dissy problem
Current Time: Thu Nov 19 21:17:31 UTC 2026
Total time taken to generate the page: 0.0084540843963623 seconds
