Toymods » Tech & Conversions » Front engine mount on a 4AGE 20V in RWD config
spectral
Front engine mount on a 4AGE 20V in RWD config Thu, 14 July 2005 10:47 Go to next message
Can I lose it?
I wouldn't be asking this question if it didn't have that bolt at the top attaching the mount to the head as well as the block..
Does this offer extra strength between the block and head?
Its quite a hefty cast iron mount, and I'm building a 550kg Clubman, so every kilogram saved helps.
Spectral.
shinybluesteel
melbourne
Re: Front engine mount on a 4AGE 20V in RWD config Thu, 14 July 2005 11:08 Go to previous messageGo to next message
the one that sticks through the cam belt cover?
piss it off, or post pics. my smallport 4age (fwd) has had this bracket removed.
spectral
Re: Front engine mount on a 4AGE 20V in RWD config Fri, 15 July 2005 01:47 Go to previous messageGo to next message
so it doesn't provide any bracing/support at all?
Why did toyota go to the obvious effort of extending it to bolt onto the head then? Confused Bizarre.
[Updated on: Fri, 15 July 2005 01:52]
Re: Front engine mount on a 4AGE 20V in RWD config Fri, 15 July 2005 01:49 Go to previous messageGo to next message
Yeah i got rid of it also.
takai
Re: Front engine mount on a 4AGE 20V in RWD config Fri, 15 July 2005 02:21 Go to previous messageGo to next message
Ditto, smallports dont have it going to the head either. Nor do GZEs
spectral
Re: Front engine mount on a 4AGE 20V in RWD config Fri, 15 July 2005 04:02 Go to previous messageGo to next message
hmm so its a new thing for the 20Vs.....
thanks everyone, is there anyone with 20V motors than have removed it? (Seeing as its different from the 16V and GZE)... car will be doing a fair bit of track work, so lots of 6000rpm+ time Smile
4a-c
Sutherland Shire
Re: Front engine mount on a 4AGE 20V in RWD config Sat, 16 July 2005 03:25 Go to previous message
yep mine is removed. is rwd and has been going strong for year and a half now no prob's
Previous Topic:RA40 brakes for KE55 problems
Next Topic:Springs and spring rates for coil over!
Current Time: Thu Nov 19 15:18:21 UTC 2026
Total time taken to generate the page: 0.0050220489501953 seconds
