Toymods » Tech & Conversions » moving the turbo housing?
MR. 2
Parramatta
moving the turbo housing? Thu, 14 July 2005 23:21 Go to next message
Guys i figured out my issue with the turbo hitting the firewall, some how the hosing of the turbo has spun and now hitting the firewall, what i need to know is how can i move it back, the rear of the housing i think has 6 bolts do i completly undo these to turn the housing to where i want it? or do i undo them completly???
Re: moving the turbo housing? Thu, 14 July 2005 23:34 Go to previous messageGo to next message
So long as things aren't rusted tight, you should be able to just back the bolts off and give the housing a little bit of a twist no problem. If things are a bit stiff, you'll need to involve other methods (e.g. WD40, removing bolts, nice gentle tapping, etc.) If you're not confident of accidently damaging nothing, then it's a lot cheaper to con someone who's done it before to come have a look than to bend something - although you have to be pretty clumsy to do damage.
spectral
Re: moving the turbo housing? Fri, 15 July 2005 01:44 Go to previous messageGo to next message
you shouldn't have to touch any bolts on a CT26/CT20. Its the compressor housing that spins, not the turbine(exhaust) housing, thats fixed to the manifold and the dump pipe.
Just take off the intake pipe into the turbo and remove the exit pipe to the intercooler.
Then grip the compressor housing firmly and twist it back towards the correct position.
Normally the turbo won't spin as there is a locating pin in the housing to prevent it. But if its moved, that means the locating pin is not present or is broken or something, so it *should* spin. If it doesn't then you'll need to get out the C-clip pliers to loosen its grip on the housing.
I'm suprised you aren't having boost control problems on your car if the housing has rotated a fair bit. As the wastegate actuator is mounted on the housing.
(This is all presuming you have the stock turbo of course)
[Updated on: Fri, 15 July 2005 01:45]
davedave
Re: moving the turbo housing? Fri, 15 July 2005 01:46 Go to previous messageGo to next message
I thought the same thing, but he's not running a CT26
MR. 2
Parramatta
Re: moving the turbo housing? Fri, 15 July 2005 03:02 Go to previous message
the turbo is a gt35 and its newish so i should have the problems with rust. cheers guys
Previous Topic:1jz probs
Next Topic:4AGE and 4AGZE bottom end differences?
Current Time: Thu Nov 19 17:14:09 UTC 2026
Total time taken to generate the page: 0.0065510272979736 seconds
