Toymods » Tech & Conversions » Pix of 1jz Hoses??
jzx83
Gympie
June 2005
Pix of 1jz Hoses?? Fri, 15 July 2005 00:37 Go to next message
Hi guys.
I've done a bit of searching and haven't found what I'm looking for, so I'll just ask. I need to know where some of the hoses on the intake side of the 1jz go to. One or two of them are missing/cut, and I'd really love to see some pix if possible. Ideally from about the back to the middle of the motor on the intake side, about halfway up the block. We have most of the pipes/wiring sorted, just have a couple of holdouts and we'd prefer to do them on the ground before (imminent) lifting motor in. Motor is JZX90 Chaser Auto, going into MX83 Cressida Grande. I gather that I may also need to swap ABS sensors from the back of the original auto into the Chaser auto. Is this the right approach? If so, is the sensor wheel inside the extension housing, or outside. Workshop is 200mt away so I am working from memory here, can't recall seeing it on outside of box.
Thanks for any help you can provide, including links to existing posts I've been unable to find.
Cheers Richard
EvilJack
Sutho/Hills NSW
Re: Pix of 1jz Hoses?? Fri, 15 July 2005 01:46 Go to previous messageGo to next message
might be better if you can supply photos of what needs to be connected or whats disconnected ?
petespipes
logan river brisbane
July 2005
Re: Pix of 1jz Hoses?? Fri, 15 July 2005 02:43 Go to previous messageGo to next message
email me and i will reply with pics [may be large]i dont know how to get pics onto here.stoopid. Sad
wilbo666
Re: Pix of 1jz Hoses?? Fri, 15 July 2005 12:28 Go to previous messageGo to next message
http://everest.fit.qut.edu.au/~n4150414/Random/14609Intake_manifold_driver_sid_copy-med.JPG
http://everest.fit.qut.edu.au/~n4150414/Random/14609Intake_manifold_passenger_copy-med.JPG
I don't remember where I collected these pics, but they aren't mine, so Kudos to someone else... Smile
Any help?
jzx83
Gympie
June 2005
Re: Pix of 1jz Hoses?? Sat, 16 July 2005 22:05 Go to previous message
Thanks Wilbo... and unknown originator of the photos.
One of the unconnected bits on our motor is shown in the first photo. At the bottom of the pic there is a cluster of three steel(?) pipes of various sizes. The one that has no hose on it is the one we are interested in. It is bent slightly downward at the end, suggesting that it probably heads rearwards and down. There is a similar sized steel outlet teed into the water line that runs around the block. This one is located more or less where the other (pictured) fitting is pointed. Simplest answer is that the two are linked, but is that the right answer? Also when I looked at the motor t'other day, I noticed a clip that would hold the flexible hose too. Clip was up under the manifold, and if you weren't looking for it you'd probably never see it.
Like petespipes I also haven't uploaded pix to here yet, but if I don't get my question across without them, I may have to learn. Not that keen as computer is horribly slow, but we'll see.
Thanks guys.
Cheers Richard
Previous Topic:Why no love for the 4A-C? Bullies!!
Next Topic:Fixing the rust under the tyre in an ra65
Current Time: Mon Nov 23 22:42:44 UTC 2026
Total time taken to generate the page: 0.0046460628509521 seconds
