Toymods » Tech & Conversions » Head gasket question
enki
Head gasket question Fri, 15 July 2005 01:14 Go to next message
Anyone know what the thickness of the stock 4age 100kw engine is. Im goin for an after market metal head gasket and i dont know what thickness to get it as i dont want to change the compression too much. Its for turbo application with 8.9 c/r 4agze pistons.
feral4mr2
Bundaberg, Qld.
Re: Head gasket question Fri, 15 July 2005 14:29 Go to previous messageGo to next message
by memory about 1.2mm, but i could be terribly wrong.
what sort of boost do you intend running? composite headgaskets will handle quite a good amount of boost.
with a metal headgasket normaly need to have the head and block prepared correctly, sonic lapping is normaly the preffered procedure.
enki
Re: Head gasket question Sat, 16 July 2005 12:45 Go to previous message
whatever it takes for that head gasket to fit. Just wanted to know. Boost will be about 15 maybe 20psi depending on wat power i make.
Previous Topic:How to fix crack paint, from lipping?
Next Topic:how to convert a KE70 in to a Coupe
Current Time: Thu Nov 19 15:31:13 UTC 2026
Total time taken to generate the page: 0.054641008377075 seconds
