Toymods » Tech & Conversions » diff for ae71 or ke70
cefiro
April 2005
diff for ae71 or ke70 Fri, 15 July 2005 07:30 Go to next message
help wanted please
would like to know the strongest diff i could use in a AE71 or KE70
any help is good help
Re: diff for ae71 or ke70 Fri, 15 July 2005 07:41 Go to previous messageGo to next message
probably from a truck.. maybe a mack???
actually, i think those mining dump trucks probably have the biggest ones...
maybe you should say what the purpose... there is always something stronger, but it's where you stop that is important.
ie, do you really need a 9" that is set up for a 2000hp drag car? or will an S series really do the job...
cefiro
April 2005
Re: diff for ae71 or ke70 Fri, 15 July 2005 08:12 Go to previous messageGo to next message
im building one with a sr20det set up for drift and track work
ive been told to use a import corona diff but was looking for other suggestions
Re: diff for ae71 or ke70 Fri, 15 July 2005 08:20 Go to previous messageGo to next message
which diff does the "import corona" have? S, T, F G, ?? B, U, ??
cefiro
April 2005
Re: diff for ae71 or ke70 Fri, 15 July 2005 08:25 Go to previous messageGo to next message
i think there a g series also out of a 2.4 ltr full injected aussie corona
someone said a t series out of a early celica may also do the job
Re: diff for ae71 or ke70 Fri, 15 July 2005 13:25 Go to previous messageGo to next message
Aussie Corona = bogwarmer.
I've got a G diff from an early Hilux in my KE70, and it loves me. I know it does. It'd be my suggestion though, the mining truck diffs are a bit of a bugger because the centre is usually bigger in diameter than any wheels you'll fit under a Corolla. Unless you'd considered turning it into an overlander Laughing
timottaway
Re: diff for ae71 or ke70 Mon, 18 July 2005 11:19 Go to previous message
2.4ltr corona st142?
irs f series....
import corona diff ure refering to could it be a t series ?
Previous Topic:Help: AE71 Corolla Rear Drum Keeps bursting.
Next Topic:so I did my auto to manual conversion....
Current Time: Sat Oct 17 23:59:43 UTC 2026
Total time taken to generate the page: 0.0058889389038086 seconds
