Toymods » Tech & Conversions » JZA61 accelerator cable
wilbo666
JZA61 accelerator cable Fri, 15 July 2005 14:16 Go to next message
OK, I just want to make sure...
I suspect the stock MA61 supra accelerator cable is a few cm to short, is there anything easily acquirable from the wreckers, I had a good look but found the ma61 one to be long already, esp compared to most of the other stuff! (i.e. cheap), or do I need to find an ex 1/2JZGTE one?
draven, norbie etc, what did you use?!
Am I stuck looking for a JZA70, JZZ30, JZX81, JZX91 accelerator cable? Will these all fit OK? Smile
If so anyone got one they want to donate to my good cause (or that I can procure cheaply?)? Wink
TRD_Supra
On Probation
Hobart
Re: JZA61 accelerator cable Fri, 15 July 2005 15:06 Go to previous messageGo to next message
just goto your toyota dealer and ask for one Razz a JZA61 cable that it
peeack
Re: JZA61 accelerator cable Fri, 15 July 2005 15:11 Go to previous messageGo to next message
And recieve what, a blank stare? There's no such thing as a 'jza61'
TRD_Supra
On Probation
Hobart
Re: JZA61 accelerator cable Fri, 15 July 2005 15:17 Go to previous messageGo to next message
hence the Razz, mind u saying that i ask them at my toyota dealer for stuff and i tell them 84 Celica Supra and they reply MA70 ?
[Updated on: Fri, 15 July 2005 15:18]
Re: JZA61 accelerator cable Fri, 15 July 2005 22:12 Go to previous messageGo to next message
Try a KE70 cable, no promises, but it might be long enough - a cable that's too long is easy to shorten, it's the other way round that creates a problem.
Re: JZA61 accelerator cable Sat, 16 July 2005 07:16 Go to previous messageGo to next message
I used a JZS147 Aristo throttle cable - perfect fit. If you can find someone who bought an Aristo half cut you might be able to nab it. Failing that, head to the wreckers with a measuring tape and see what you can find. I have a feeling an RA65 cable might be a good bet since they have a front-mounted throttle.
wilbo666
Re: JZA61 accelerator cable Sat, 16 July 2005 11:11 Go to previous messageGo to next message
Norbie wrote on Sat, 16 July 2005 17:16
Been to the wreckers....no luck as yet (had a look at pretty well all the Toyota's Sad ). RA65 has the throttle on the drivers side (if I recall correctly) vis a vis passenger on the 1jz...hmm don't think it'll work...but I'm not sure! I haven't seen an RA65 at a wreckers in ages believe it or not...a fair few RA60's but not 65's.
For reference the MA61 cable is approx 1200mm end to end (that's a rough measurement btw so give it a bit of leeway!)
I'll post a wanted as well Smile
Re: JZA61 accelerator cable Sat, 16 July 2005 14:45 Go to previous messageGo to next message
I'm using a 5MGE Mk2 cable for my 1G, it was a smidge longer than a 1GGE version, and it's a tad long for mine, as you can see from my fully sick bracket.
Re: JZA61 accelerator cable Sun, 17 July 2005 01:34 Go to previous messageGo to next message
Use the EPC to get the part number for the JZS147 cable.
Then ring Toyota and get a price.
If its anything like other cables it will be about $75 I think.
I know this is probably WAY out of your student price range, but you get that Razz Razz Razz
wilbo666
Re: JZA61 accelerator cable Sun, 17 July 2005 12:48 Go to previous message
CrUZsida wrote on Sun, 17 July 2005 11:34
haha, I only have an oldschool EPC so no chance of getting it off mine...
and yes you are correct, $75 is well outside my student price range Razz
*kicks self*
have a nice day Razz
Previous Topic:Using a Turbo computer on a Supercharger?
Next Topic:times for celicas
Current Time: Sat Nov 21 16:05:02 UTC 2026
Total time taken to generate the page: 0.0049450397491455 seconds
