Toymods » Tech & Conversions » difference between torsen and clutch LSD's (Supra)
RAWS
Adelaide Street Racing ca...
difference between torsen and clutch LSD's (Supra) Sat, 16 July 2005 05:31 Go to next message
Hi all,
I have an MA70 which im told has a clutch type LSD. Heaps of people seem to have or are fitting the torsen LSD's. My MA70 is currently having a 1jz installed into it.
I just want to know what the actual difference is between the torsen lsd and clutch type lsd. Are the torsen diffs a lot better? Would it be worth the money installing one into my car? (Im installing HKS T3G's and will be making around 300KW) The car will be street driven but also used for circuit racing and the odd trip to the drag strip. Thanks.
PS: Ive already searched so dont just tell me to search. If ya know the answer you could just type in instead of writing: use the search function...
RAWS
Re: difference between torsen and clutch LSD's (Supra) Sat, 16 July 2005 11:11 Go to previous messageGo to next message
BuMp
Re: difference between torsen and clutch LSD's (Supra) Sat, 16 July 2005 12:58 Go to previous messageGo to next message
clutchtype have preload, torsen type don't
torsen is more progressive and smooth, and should wear less, making it more consistent... the only downside is that if one wheel actually lifts off the ground, you may loose some drive.
cos of the way it works, but wheels need some resistance for the torsen to work, and push power to the wheel that is not slipping, but no resistance means no transfer.
the other big benefit is that when you are not accelerating, the diff is almost like a fully open diff, so no wheel hopping you get with a tight cluthc pack LSD...
just google for torsen diff and you will find heaps of info.
trevtrev
Re: difference between torsen and clutch LSD's (Supra) Mon, 18 July 2005 06:38 Go to previous message
There are a lot of pages here but read them all or just go to the section on Torsen.
http://auto.howstuffworks.com/differential.htm
Previous Topic:Strut and brake conversion
Next Topic:1GGTE+J160 into RA60..anyone?
Current Time: Wed Oct 21 02:56:27 UTC 2026
Total time taken to generate the page: 0.0060601234436035 seconds
