Toymods » Tech & Conversions » Whats Your 4 Spot Calliper?
spectre
icon4.gif  Whats Your 4 Spot Calliper? Sun, 17 July 2005 03:45 Go to next message
Doing some research into Calliper and Strut combinations and I need your help!
Whats Your 4 Spot Calliper:
Name, Year and Model the Calliper came from?
Centre to Centre / Eye to Eye bolt up distance?
Whats your Strut:
Name, Year and Model the Stut came from?
Bolt up distance Centre to Centre / Eye to Eye for the Calliper bracket?
(Feel free to add information concerning 2 spot callipers if you wish!)
This could turn into a great resource for anyone looking to do a brake upgrade!
Bryce
September_Squall
Melbourne, Australia
March 2005
Re: Whats Your 4 Spot Calliper? Sun, 17 July 2005 04:24 Go to previous messageGo to next message
Can I be the first one to say...
LN106 Toyota Hilux caliper (90mm spacing)
RT132 Toyota Corona strut (as above)
You do realise these two specs are only the beginning...?
Re: Whats Your 4 Spot Calliper? Sun, 17 July 2005 07:49 Go to previous messageGo to next message
R33 GTS-t Skyline calipers, 100mm bolt spacing I believe.
MX83 Cressida struts.
170bhp
Re: Whats Your 4 Spot Calliper? Sun, 17 July 2005 07:53 Go to previous messageGo to next message
spectre I use FD series 7, try and get your hands on these as they have different sized pistons to stop pad taper as they wear. I use an 282mm rotor on ae86 struts.
wagonist
Toymods Club Treasurer
Re: Whats Your 4 Spot Calliper? Sun, 17 July 2005 08:15 Go to previous messageGo to next message
ST205 GT4 calipers. 130mm bolt spacing
stock steering knuckles modified to accept bolt in stock location
ST205 discs machined from 315mm dia to 300mm
stock struts
Follow the link in my sig for a better picture Wink
Non Toyota:
MY99 WRX calipers & discs on MY93 WRX steering knuckles & struts mounted to 88 L series wagon with modified lower control arms.
spectre
Re: Whats Your 4 Spot Calliper? Mon, 18 July 2005 08:46 Go to previous messageGo to next message
bump!
CLG
Perth, Western Australia
Re: Whats Your 4 Spot Calliper? Thu, 21 July 2005 04:24 Go to previous messageGo to next message
Norbie wrote on Sun, 17 July 2005 15:49
Do your callipers bolt up without the need for an adapter Norbie?
Re: Whats Your 4 Spot Calliper? Thu, 21 July 2005 04:50 Go to previous messageGo to next message
Yes.
http://www.norbie.net/Project2JZ/BrakeUpgrade/
blackRA28
adelaide
Re: Whats Your 4 Spot Calliper? Thu, 21 July 2005 05:10 Go to previous messageGo to next message
Just a quick Q, im about to purchase LN106 calipers for my xt130/pug/hilux conversion into a ta23..
I got asked if i want calipers from a front LIVE AXLE or SOLID AXLE Hilux LN106...
At this point i went duh, not sure, whats the difference?
-he replied"well ones off a live axle and the others off a solid axle.."
i said "the one with 90mm bolt spacing and to take a 20mm vented disc.." and he again asked which of the two i wanted..
Can anyone confirm which type of LN106 caliper i need for the standard documented brake upgrade?
is there a visible difference in the solid-axle and live-axle versions?
just incase i need to identify them...
Laughing
Stefan
Hobart, Tas
Re: Whats Your 4 Spot Calliper? Thu, 21 July 2005 05:16 Go to previous message
Nissan R32/Z32 calipers on xA6x Supra or Celica struts. IIRC the spacing is the same, just needs an adapter (+ machining hubs & centring rim for accompanying R32/Z32 discs).
Search for Cruzida's (spelling?) thread in the tech section.
Previous Topic:Alternative alternator bracket for 4AG?
Next Topic:the ultimate 22re head
Current Time: Fri Nov 20 09:23:23 UTC 2026
Total time taken to generate the page: 0.0075829029083252 seconds
