Toymods » Tech & Conversions » 1GGTE+J160 into RA60..anyone?
cultus
Kuala Lumpur, Malaysia
April 2005
1GGTE+J160 into RA60..anyone? Sun, 17 July 2005 12:48 Go to next message
Planning to do this conversion to replace the current 20v in the car.
I am worried about the length of the J160, from bellhousing to the stick shift is 30 inches. I dont want the shifter to go too far back maybe 3 inches max. And by moving the radiator forward an inch, I think I can squeeze in this set up.
Has anyone done this before? Any pics that perhaps can share with me?
And can anyone help to measure the W57&58 gearbox? (From bellhousing to the stick shift) If i recall correctly it is 26 inches. Please confirm...thank you
JAZE
cronulla
Re: 1GGTE+J160 into RA60..anyone? Sun, 17 July 2005 12:55 Go to previous messageGo to next message
In length, the W5x and J160 are almost idedntical.
the difference is in the shift position, and this can be remedied partially by a large kink in the shifter, however perhaps relocating the shifter would work better.
moving your engine so far foward is not the best idea.
The J160 also runs the same tailshaft spline as a w58. so tailshafts are identical.
perhaps if you wanted a cheap fix, you could shorten the stick on the handbrake, bend the shifter and then cut your shifter hole in your trans tunnel back another 2 inches or so.
Re: 1GGTE+J160 into RA60..anyone? Sun, 17 July 2005 23:36 Go to previous messageGo to next message
Does the J160 have an external shifter like the V160? If so it's possible to shorten it a bit.
Lambolica
Northwestern Sydney
Re: 1GGTE+J160 into RA60..anyone? Sun, 17 July 2005 23:50 Go to previous messageGo to next message
And whist the question is up is the width and height of the J160 similar to that of the W5*? ie. if a w58 fits in the trans tunnel will the J160?
Re: 1GGTE+J160 into RA60..anyone? Mon, 18 July 2005 03:13 Go to previous messageGo to next message
http://members.optusnet.com.au/gianttomato/Toyota%20Power%20/gearboxes%20front.jpg
L -> R. T50, W58 and J160
http://members.optusnet.com.au/gianttomato/Toyota%20Power%20/gearboxes%20rear.jpg
L -> R. J160, W58, T50
As you can see, J160 shift position is a country mile behind the W58 one. I strongly doubt a simple "kink" will sort this out.
From memory "ddeane" did this mod - not sure what in. There are a few considerations - the rearward position of the shift interferes with the handbrake lever. Search for some of his posts....very informative.
Meh...here it is.
[Updated on: Mon, 18 July 2005 03:29]
cultus
April 2005
Re: 1GGTE+J160 into RA60..anyone? Mon, 18 July 2005 05:03 Go to previous messageGo to next message
Thank you guys for the info and pic.
I think I will try a combination of a shifter kink, engine forward and enlarging the hole. Might put in the GA70 dash and console, then I will have the handbrake closer to the driver side.
My gearbox has the shifter at the forward position. Bellhousing is made to match the 1G. Clutch pump is on the passenger side.
http://img128.imageshack.us/img128/7052/j1600qu.jpg
The GA70 halfcut I have in mind has an auto, but it is the cheapest I can find with a nice dash and digital dash.
Do you guys think it is a good idea to use this 1GFE flywheel/clutch(90%)/pressure plate behind the 1GGTE?
http://img128.imageshack.us/img128/6840/flywheel16nq.jpg
http://img128.imageshack.us/img128/2559/flywheel21by.jpg
By the way : I compared the clutch plate with the 4AGZE : diameter same, fits the shaft as well.
Re: 1GGTE+J160 into RA60..anyone? Mon, 18 July 2005 06:25 Go to previous message
Flywheel should be OK but I'd get a nice new heavy-duty pressure plate and clutch disc if I were you.
Previous Topic:difference between torsen and clutch LSD's (Supra)
Next Topic:Stock ECUs on differents engys
Current Time: Wed Oct 21 18:52:04 UTC 2026
Total time taken to generate the page: 0.0044388771057129 seconds
