Toymods » Tech & Conversions » 5 speed 77 Corolla conversion
shelldrake
parkdale, Victoria
May 2005
5 speed 77 Corolla conversion Mon, 18 July 2005 01:04 Go to next message
I have a 77 Corolla with a standard 3k-c motor and standard 4spd. The box has just broken and I would like to put a 5spd in it. I know that there were some 5spds put in these cars from the factory but I don't know if they used the same motor.
What 5spd box easily fits in these cars? could I use a T50?
rob_RA40
c'town, NSW
Re: 5 speed 77 Corolla conversion Mon, 18 July 2005 01:45 Go to previous messageGo to next message
a K50 gearbox should do it, u can find them in some KE55's and KE70's except for panel vans had them
both cars had K motors and the box will bolt up.
shelldrake
parkdale, Victoria
May 2005
Re: 5 speed 77 Corolla conversion Mon, 18 July 2005 03:34 Go to previous messageGo to next message
Will I have to change the clutch, flywheel, tailshaft or crossmember for this conversion?
Re: 5 speed 77 Corolla conversion Mon, 18 July 2005 03:38 Go to previous message
KE55 has the correct shifter position, KE70 has shifter further back, and also has different rear crossmember mounting method.
you can easily swap a KE55 extension housing onto KE70 box tho.
nope, if you use a KE55 5 speed, or a KE70 5 speed with KE55 5spd extension housing, you will not need to change anything if you are going form a 4 speed. going from an auto there are sometimes driveshaft and cross-member issues (thanks to the traumatic 3 speed)
T50 will need diferent bellhousing, clutch, flywheel, and rear cross-member, and possibly hydraulic clutch pedal...
maybe you could use driveshaft if it is the smaller spline T50 output shaft
Previous Topic:AW11 stock ECU location
Next Topic:4AGE feels sluggish
Current Time: Sat Oct 24 03:59:54 UTC 2026
Total time taken to generate the page: 0.0083489418029785 seconds
