Toymods » Tech & Conversions » 108mm 4agze pulley what belt do i need?
Hodgo
108mm 4agze pulley what belt do i need? Mon, 18 July 2005 06:06 Go to next message
Hi all,
Just put on a small (108mm) SC pulley and my belts too long anyone happen to know what belt would suit?
Regards Hodgo
4agte
Toronto, Downtown
Re: 108mm 4agze pulley what belt do i need? Mon, 18 July 2005 07:02 Go to previous messageGo to next message
work out how much shorter the belt needs to be go to the auto store take the old belt and ask for the same width/rib belt only the ammount smaller
Hodgo
Re: 108mm 4agze pulley what belt do i need? Mon, 18 July 2005 07:44 Go to previous messageGo to next message
Thanks, but it is still a black art as the circumference is not the same as the surface that touches the belt.
Just tried 3 diff lengths, running back to the parts shop to give it another go Mad
gearb0x
Re: 108mm 4agze pulley what belt do i need? Mon, 18 July 2005 07:46 Go to previous messageGo to next message
tried some string wrapped around the path of the belt?
Hodgo
Re: 108mm 4agze pulley what belt do i need? Mon, 18 July 2005 08:21 Go to previous messageGo to next message
3 too small, now 2 too big..... at least i know what i need to get tomorrow.
feral4mr2
Bundaberg, Qld.
Re: 108mm 4agze pulley what belt do i need? Mon, 18 July 2005 12:23 Go to previous messageGo to next message
being a flat multi rib 5pk belt, if you wrap some string around the path needed and get a measurement you cannot go wrong in finding the right length belt required. you should have enough adjustment on the tensioner idler for 5-10mm in belt length difference.
Re: 108mm 4agze pulley what belt do i need? Mon, 18 July 2005 12:40 Go to previous messageGo to next message
Hodgo wrote on Mon, 18 July 2005 17:44
actually, not that black..
basically... if the belt is Amm thickness, the outside does a fixed amount more distance than the inside...asuming the belt is a circle, and the difference in radius is Amm.. the difference in circumference is 2Pi(R+A) - 2PiR = 2PiA
ie approx 6.3mm longer for each mm of belt thickness, so if belt is 4mm thick (from bottom of rib grooves) the outside will be 25.2mm longer than the inside....
i would be very interested for you to try this since you have the belt off anyway Wink
edit: this works for any circle things, ie race tracks (maybe american ones Razz).. 1m further out from a certain line means you have 2Pi x 1 metres further to travel, ie 6.3meters for each extra meter you are further out... soa car width of what? 3m = 18m further distance... aaaanyway
[Updated on: Mon, 18 July 2005 12:43]
Hodgo
Re: 108mm 4agze pulley what belt do i need? Tue, 19 July 2005 04:57 Go to previous message
I agree but there is also the fact that the belt does not wrap around the whole pulley only like 2/3rds or sumin.
Anyhoo i gotz one now but thanks for the help all.
Previous Topic:4AGE 20V V.S CA18DET N13 pulsar
Next Topic:A few Q's for LEXUS LS400 models
Current Time: Tue Oct 13 00:06:54 UTC 2026
Total time taken to generate the page: 0.12303400039673 seconds
