Toymods » Tech & Conversions » NEED HELP 4AGTE........no start
ke35 - 4AGZE
NEED HELP 4AGTE........no start Mon, 18 July 2005 06:15 Go to next message
hey everyone,
need some help,
i just finished a 4agze to 4agte conversion and i'm having troubles starting it,
problem: no spark
i dont know what the problem is, as everything was working before i started the conversion..
ignitor should be fine, ecu hasnt been touched, plugs and coil packs havnt beed touched..
what could the problem be??
any help appreciated..
anyone keen to come have a look and help me sort it out??
James
EMP-2TG
Carlingford, Sydney
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 06:42 Go to previous messageGo to next message
havent changed the earth or anything like that?
ae86slaver
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 07:00 Go to previous messageGo to next message
- battery (jump it if need be)
- check the alternator wires (sometimes they corode and need a wiggle)
- starter motor wires
- earth wires (sometimes these are a bastard - in particular check the ignitor pack, it needs a firm earth!)
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 07:01 Go to previous messageGo to next message
nah i checked my earth's, they are all ok...
thanks josh
i cant figure it out..
all the wiring in my car needs to be re done.. its f*cked atm..
I'm so stuffed ..
[Updated on: Mon, 18 July 2005 07:01]
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 07:06 Go to previous messageGo to next message
ae86slaver wrote on Mon, 18 July 2005 17:00
how do you mean jump the battery??
il try the alternator wires
i know the starter motor wires are ok, checked and rechecked today, i was struggling to get the starter to work
yep checked all earths
yeah i had a bad earth on the ignitor pack once before so i checked that and it is firmly earthed...
anyone want to lend a hand?? Razz i'l shout a case of beer if someone can fix it Very Happy
ae86slaver
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 07:10 Go to previous messageGo to next message
its prolly something simple man.
so if u turn the key, nothing happens?
jump the battery as in, if your battery is flat, get some jumper leads and hook it up to another car, and try starting it - it's most probably dead since it has been sitting there so long
This happened to my car after 2 weeks it was sitting there for the turbo conversion, the battery went COMPLETELY flat and i had to get another battery to make it start and run
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 07:17 Go to previous messageGo to next message
oh, Razz
nah was doing that anyway, even though i have had the battery on charge.
yeah i know its probably simple but i just cant find it..
yeah it cranks and has fuel but no spark...
its so frustrating because i have been wiating sooo long to start it and it wont start...
thanks for your help
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 07:26 Go to previous messageGo to next message
so would anyone be interested in coming around to help??
ae86slaver
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 07:34 Go to previous messageGo to next message
hmmm other than those things, i would be out of ideas if i came round
must be something to do with the coil packs/leads/wiring
check if they are all plugged in firm!
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 07:37 Go to previous messageGo to next message
damn,
yeah thats what i figure to, but as you said i have checked all the plugs and everything seems fine..
how do i know if the crank angle sensor is working??
James
4agte
Toronto, Downtown
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 07:39 Go to previous messageGo to next message
have you tried running a diagnostics on it???
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 07:42 Go to previous messageGo to next message
i dont think i can do that, atm my instrument panel isnt in, does this make a difference,
and i dont think i have a check engine light... Sad
4agte
Toronto, Downtown
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 07:45 Go to previous messageGo to next message
fair enough mayb you could hook a test light to the wires or something
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 07:49 Go to previous messageGo to next message
yeah i can do that..
so what do i need to do??
do you know what ecu output goes to the check engine light??
and what do you short to do the diagnostic check??
cri_ag
northern beaches
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 08:01 Go to previous messageGo to next message
while i was reading your other thread regarding the progress of your 4agte conversion i noticed you mentioned that you shorted a 12v source to your braided line, did you blow a fuse or similar in doing this?
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 08:06 Go to previous messageGo to next message
Shocked
good thought!
but i have checked all fuses and i shorted 12v straight off the battery to the line so there wasnt any fuse to blow, it would have blown a fuse if there was one to blow.
4agte
Toronto, Downtown
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 08:10 Go to previous messageGo to next message
ke35 - 4AGZE wrote on Mon, 18 July 2005 17:49
i can answer the second part you need to get the diagnostic thingy its a black box with a lid take the lid off and use a paper clip and put one end in the "T" terminal and the other end in the "E1" terminal.
[Updated on: Mon, 18 July 2005 08:24]
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 08:23 Go to previous messageGo to next message
ahh thanks ive been looking for that since you said it...
the tech docs arnt the easiest to navigate.. Rolling Eyes
and i couldnt find a direct answer searching for it.
so should this black box be close to the ecu??
and does anyone know how i can hook up a check engine light to a 4AGZE ecu??
4agte
Toronto, Downtown
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 08:28 Go to previous messageGo to next message
http://www.mr2mk1club.com/repairsp76.html
that might help
the diagnostic plug in the mr2 is near the ecu at the boot side of the engine bay so it may well be the close to the ecu for you as your using the mr2 loom arent you
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 08:32 Go to previous messageGo to next message
thanks i'm looking at the site now,
im actually not %100 sure which version of GZE i actaully have,
as i have airflow meter and coilpacks/ crank angle sensor, and i can never get an acurate answer as to the model of GZE i have, but yes im using the standard loom,
i was also told that i had a slightly better ecu when i bought the car but i dont think this sounds right...
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 08:42 Go to previous messageGo to next message
and also, if i figure out how to do a diagnostics check how do i read the lamp??
eg, is it 12 flashes for a code 12??
4agte
Toronto, Downtown
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 09:13 Go to previous messageGo to next message
it will flash once then pause for about 3-5 seconds then flash twice so 1 + pause + 2 = 12
feral4mr2
Bundaberg, Qld.
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 10:10 Go to previous messageGo to next message
ke35 - 4AGZE wrote on Mon, 18 July 2005 18:32
that would be a bigport 8.0:1 c/r version from the AE92 FWD Levin/Trueno.
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 11:01 Go to previous messageGo to next message
Very Happy
hey thanks feral4mr2
thats what i thought as well!!! thanks! good to have my suspicions confirmed!! Very Happy
thanks for that 4agte, youve been very helpful, i'l try to figure it all out as soon as possiible.
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 11:06 Go to previous messageGo to next message
8.0:1 c/r?? so is this lower than the other GZE's??
8.9:1 for other??
would this be better for more "boost"???
ae86slaver
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 11:19 Go to previous messageGo to next message
well thats what they say, this version (same as mine Very Happy ) with the bigports and lower compression/coil packs is great for more boostage Razz
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 11:26 Go to previous messageGo to next message
Very Happy
he he he he.... oh the possibilities.... Razz
will i be limiting the boost to 20psi once i change the ecu??? hmm thats a good question Very Happy
thanks ae86slaver,
fun times ahead Very Happy
ae86slaver
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 11:28 Go to previous messageGo to next message
good tune my friend, good tune, no boundaries for boost with a different computer!
i'd limit it to 14psi on the stock comp, goes hard still, on the track it felt nuts Smile
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 11:35 Go to previous messageGo to next message
yep i hear ya,
the acuator on my turbo is set at 1 bar so its about perfect..hehe
and bigger injectors..etc etc.. Rolling Eyes
so your running 14psi atm?? and it goes nuts?? thats awsome!! Very Happy cant wait to solve this problem and get onto the track and give it a thrashing!! Evil or Very Mad
bantech
Bathurst
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 11:44 Go to previous messageGo to next message
This may be way off - but I remember years ago when I shorted a battery to earth while it was still in the car I blew one of the fusible links. One of the big buggers with a clear top that should sit right next to the +ve battery terminal
have you checked the fusible links? Just a thought.
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 11:49 Go to previous messageGo to next message
hey,
thanks, i havnt, but i will
the problem is ive checked all the fuses i can find
but il have a look to see if i can find any fusible links,
bantech
Bathurst
Re: NEED HELP 4AGTE........no start Mon, 18 July 2005 11:55 Go to previous messageGo to next message
There should be 3 in a row basically at the +ve terminal post(I know the car is obviuously not stock.)
They're about 1cm sq with a clear top and coloured sides. If you used a standard loom they maybe under a cover.
Good luck.
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Tue, 19 July 2005 12:03 Go to previous messageGo to next message
ok thanks,
TE72_Turbo
Re: NEED HELP 4AGTE........no start Tue, 19 July 2005 13:14 Go to previous messageGo to next message
So you say you have fuel, so the motor cranks over, you can hear the fuel pump running, and the injectors are firing? If so, the CAS must be okay, cause the injectors wouldn't operate if the ECU was not seeing an rpm signal from the cranking engine....
Sounds as if your problem may be isolated to the coilpacks/ignitor
good luck! Smile
sideshow
Re: NEED HELP 4AGTE........no start Tue, 19 July 2005 13:50 Go to previous messageGo to next message
if u have enough tryin to find prob give me a yell
and i can check it out for a price
what part of sydney are u from
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Tue, 19 July 2005 21:32 Go to previous messageGo to next message
TE72_Turbo wrote on Tue, 19 July 2005 23:14
good luck! Smile
ahh ok,
well i dont know if the injectors are actually firing but i know i have fuel in the rail, the pump in running and i can hear fuel in the lines...
thanks for that
thanks for that,
a friend is coming to help me out on sunday, but if we cant work it out then il give you a call,
i live in padstow, sorta in the bankstown area but on the way to menai...
James
Darola
Taree, 4h nth of syd
Re: NEED HELP 4AGTE........no start Sun, 24 July 2005 23:49 Go to previous messageGo to next message
hey there,
do u have power at the ecu???
i had a simaler problem with a mates car, found it to be in inline fusible link had blown, it comes off the battery b+ and looks like a thick wire, undo some of the tape to find it
i found this blowen and wasnt giveing the computer power so there was no spark, but it still cranked
hope this helps
Eddie
Darola
Re: NEED HELP 4AGTE........no start Sun, 24 July 2005 23:52 Go to previous messageGo to next message
No Message Body
[Updated on: Sun, 24 July 2005 23:54]
ke35 - 4AGZE
Re: NEED HELP 4AGTE........no start Mon, 25 July 2005 05:44 Go to previous message
Darola wrote on Mon, 25 July 2005 09:49
hey there,
hope this helps
Eddie
um yeah got power to ecu,
had it running on the weekend, was good,
now once again it has no igntion, so looks like i'm screwed.
James
Previous Topic:2jz-gte aristo swap into an s13... :P
Next Topic:MA70 tailshaft strength? How strong are they?
Current Time: Sat Oct 24 14:57:50 UTC 2026
Total time taken to generate the page: 0.018193006515503 seconds
