Toymods » Tech & Conversions » 4agze: No real difference with ABV mod?.
MaNGeW
Formerly TRD_RoLLa
icon5.gif  4agze: No real difference with ABV mod?. Wed, 11 December 2002 13:26 Go to next message
Ok today, after following information obtained from mr2 owners club. I did the ABV modification to my 4agze.
I T-pieced the brown VSV which goes to the inlet manifold with the tube that goes from the ABV which was attached to the blue VSV (which i blocked off)
have i lost ya yet?
With that done i blocked off the other tube from Blue VSV leading to the Throttle body.
Hence nothing is attached to Blue VSV. It still has a plug on it.
Im not sure if this is right.
Anyways, i went for a spin. Didnt reallly noticed any chance at all. Still peaks at same PSI.
I know of ppl who done this mod. and achieved from 8psi to 10psi.
This is with the standard pulley.
have i stuffed up?
Rolling Eyes
feral4mr2
Bundaberg, Qld.
Re: 4agze: No real difference with ABV mod?. Wed, 11 December 2002 21:29 Go to previous messageGo to next message
Freak no, you did it correctly.......
take your intercooler off and flush it with all purpose paint thinners, i picked up 1psi when i did it ages ago...Smile
whiteGZE
Western Sydney
Re: 4agze: No real difference with ABV mod?. Thu, 12 December 2002 05:35 Go to previous message
This is normal Smile
If your sc is producing more than 8psi boost then disbaling the abv will give you that extra boost. Otherwise it should feel the same.
The 4agze is designed to produce 8psi so there shouldn't be an increase unless the sc or crank pulley is a different size.
There may be slight differences between engines that could cause a slightly higher than usual boost level.
Previous Topic:Traction Control
Next Topic:What can I change my 7M-GE for?
Current Time: Sat Nov 21 07:57:01 UTC 2026
Total time taken to generate the page: 0.0041110515594482 seconds
