Toymods » Tech & Conversions » 1J vs 2J turbo dump pipes
joorsh
1J vs 2J turbo dump pipes Mon, 18 July 2005 14:33 Go to next message
I'm in a situation where I can get a very good set of custom made 1JZGTE dump pipes to fit the standard turbo's. I want to know if this will also fit the standard JZA80 Jap-spec 2JZGTE turbo setup.
Any takers?
petespipes
logan river brisbane
July 2005
Re: 1J vs 2J turbo dump pipes Mon, 18 July 2005 15:15 Go to previous messageGo to next message
Hi joorsh,sorry its a no,the 2J stock turbos are a totally different shape.Not even close.Cheers.Pete. Crying or Very Sad
Re: 1J vs 2J turbo dump pipes Mon, 18 July 2005 23:18 Go to previous messageGo to next message
Twin dumps on a 2JZ will be pretty difficult to do because there's not much room between the turbos. The exhaust housing on the #2 turbo is quite big as it accomodates the exhuast bypass valve. I'm going to have a go at this when I install the external wastegate on my engine, but I don't like my chances. Sad
joorsh
Re: 1J vs 2J turbo dump pipes Tue, 19 July 2005 00:15 Go to previous messageGo to next message
Yeah I knew the turbo's were quite different, but I was more hoping the bolt/stud pattern and distance between the exhaust housings on the turbo's may be the same. That way I could still fit the 1J dump pipe.
Re: 1J vs 2J turbo dump pipes Tue, 19 July 2005 02:12 Go to previous message
If only that were the case, but I'm afraid you're fresh outta luck. Sad
Previous Topic:MA61 Aftermarket ECU & Cruise Control Question
Next Topic:Cam to dizzy drive ratio?
Current Time: Sun Oct 18 06:59:31 UTC 2026
Total time taken to generate the page: 0.031933069229126 seconds
