Toymods » Tech & Conversions » 1J factory metal turbo flange gaskets-always 2 a side?
petespipes
logan river brisbane
July 2005
1J factory metal turbo flange gaskets-always 2 a side? Tue, 19 July 2005 03:05 Go to next message
Hi,I am looking for confirmation that it is always 2 metal gaskets a side between the stock Y dump and the ct12a turbo.I would like to get at least 10 confirms on this so I can lay the matter to rest for all time.
If it is proven that it is a varying number of gaskets then I will be trying to understand why?
Thanks in advance,if you know which car and year the 1J was from that would be good also.Cheers.Pete. Smile
Soarer
Wollongong
Re: 1J factory metal turbo flange gaskets-always 2 a side? Tue, 19 July 2005 07:53 Go to previous messageGo to next message
Single metal gasket between my stock cast dump and each turbo.
ie. one per side.
Never seen a setup with 2 gaskets per side if I understand your post properly.
Nisota
NZ
Re: 1J factory metal turbo flange gaskets-always 2 a side? Tue, 19 July 2005 11:49 Go to previous messageGo to next message
mine had 2 each side
petespipes
July 2005
Re: 1J factory metal turbo flange gaskets-always 2 a side? Tue, 19 July 2005 14:40 Go to previous message
thanks guys,this confirms what I heard from Camo although I personally have only seen 2 ea side.This must be Toyotas way of allowing for small variations in the various castings.
2x3into 1 exhaust manifolds
2 turbos
1 Y dump pipe
The flange gaskets seem to be the only variable,all the other components being the same regardless of car model using the pair of ct12a's.Cheers.Pete.
Previous Topic:Collapsible Steering Columns
Next Topic:Something Stupid!!!
Current Time: Sat Oct 17 07:06:32 UTC 2026
Total time taken to generate the page: 0.019744873046875 seconds
