Toymods » Tech & Conversions » 4.5 ratio?
Evan
4.5 ratio? Tue, 19 July 2005 04:45 Go to next message
Would a 4.5 ratio in a T18 diff fitted to an AE86 be too short for an sr20det conversion.?
Would the gear ratio's be too short for that setup?
kingmick
Banned by his request
moved to tamworth
Re: 4.5 ratio? Tue, 19 July 2005 05:41 Go to previous messageGo to next message
depends on the gearbox ratio aswell! prob a bit short for the street!if you want to sell the 4.5 i know someone that needs one. with any sort of higher boost youll be spinning 5th with a 4.5 which could be fun!
mick
Evan
Re: 4.5 ratio? Tue, 19 July 2005 05:54 Go to previous messageGo to next message
yeh i was thinking that.
Its just that the cheapest ratio is the 4.5.
i could go with the 4.1.
Sholud be ok
kingmick
moved to tamworth
Re: 4.5 ratio? Tue, 19 July 2005 06:33 Go to previous messageGo to next message
3.9 would be better,but 4.1 will be ok for keeping it going of boost etc.maybe instead of ratios they should have "spins to secound,spins to third,spins to four and i use the drivers door window to see were to go.
mick
Henn
Rosanna, Melb
Re: 4.5 ratio? Tue, 19 July 2005 13:17 Go to previous messageGo to next message
Through a T50 and a 3.9 diff, 100km/h is 3200rpm in 5th gear.
4.5 will therefore give you about 3700rpm at 100 (assuming the SR20 box has a similar 5th ratio to a T50).
Possibly a bit short in my opinion. Great for rally but maybe not great for road use.
However, with an SR20 in such a light car I doubt the diff ratio will matter too much, you'll have enough torque everywhere to do whatever you want to do.
Hen
kingmick
moved to tamworth
Re: 4.5 ratio? Tue, 19 July 2005 21:27 Go to previous message
lol i think its safe to say it wont be a t50 going behind the sr20det.couldnt imagine it lasting very long.Smile
mick
Previous Topic:lowering springs
Next Topic:Desired temp range of water temp sender for Thermo fans ???
Current Time: Fri Nov 20 01:44:52 UTC 2026
Total time taken to generate the page: 0.0050358772277832 seconds
