Toymods » Tech & Conversions » HELP! MA61 Overheating
ZZT231
melbourne.vic.au
HELP! MA61 Overheating Wed, 11 December 2002 22:30 Go to next message
Hey All.
As the title states. My car is overheating and don't know what to do. Is it better to stay on the original Fluid Couple Fan or remove the OEM Fan and go Electric Thermos?
If Electric Thermos, is there such a kit avaliable which can be bolted up to my MA61 with the 5M-E motor? I heard it would be a bugger of a job trying to install the Thermo Switch to tell the fan to turn on and I really don't want a manual controlled fan because you can always forget...
Cheers.
ZZT231
melbourne.vic.au
Re: HELP! MA61 Overheating Wed, 11 December 2002 23:00 Go to previous messageGo to next message
Also i forgot to mention is that the car has had it's radiator replaced, system flush out and thermostat replaced.
And no... I haven't blown the head gasket. The Couple Fluid clutch is dead, when the engine is HOT the fan can freely move in round circles not drawing in air when it was meant to have a lot of resistance especially when the engine is on sucking air from outside in.
Remedy
Southern Sydney
Re: HELP! MA61 Overheating Wed, 11 December 2002 23:01 Go to previous messageGo to next message
Is it overheating in traffic or while driving?
If its while your moving then electric thermo fans probably won't help much.
Look at your original equipment and find where the problem is before you start replacing stuff.
ZZT231
melbourne.vic.au
Re: HELP! MA61 Overheating Wed, 11 December 2002 23:20 Go to previous messageGo to next message
Its usually after a long run and the car is slowing down to 60kph in traffic the temperature creaps up.
I usually try and find clean uninterupted air to drive to keep the engine cool but during rush hour... no hope.
Cheers.
Re: HELP! MA61 Overheating Thu, 12 December 2002 00:27 Go to previous messageGo to next message
The fan in my Celica isn't working great, my mechanic said the fluid they use in the fans loses its viscous effect. You can get a new bottle of fluid from Toyota, remove it and fill it up.
The factory fans work pretty well so I'd be thinking thats a good option.
PayneyCelica18rg
Southport
Re: HELP! MA61 Overheating Thu, 12 December 2002 00:49 Go to previous messageGo to next message
if you can find thermos that fit, i would look at removing the fluid fan and fitting them. if you can't work find out the wiring for the fans, i would see my local repco dudes and pick up a thermo switch and get it mounted into the cooling system somewhere. I would recommend near the thermostat, but it might be cheaper to have a radiator dude fit it into the radiator.
Re: HELP! MA61 Overheating Thu, 12 December 2002 08:48 Go to previous messageGo to next message
The factory clutch fan works brilliantly if in good working order. I wouldn't bother with electric fans unless you have a good reason for it (eg engine upgrade). Just find another clutch fan that works.
SupraBOY
Yeppoon/Rockhampton
Re: HELP! MA61 Overheating Thu, 12 December 2002 09:11 Go to previous messageGo to next message
I'd say it would be your water pump.
Before i got my new engine i changed the radiator and thermostat. You'll probably find that it's your water pump that needs replacing.
If you haven't had this replaced in years get it done asap. Mine blew up on the highway and it wasn't a preety site because i ended up having to get a new engine.
pop your bonnet and give the car a few revs. if water appears to be flying around and you don't know where it's coming from it's teh water pump telling you it's on it's last days.. literally.
but this might not be the case with your car.
my advice, get it checked.
another thing. i was filling my car up every week with water, there is an odd shaped pipe that runs around the engine and mine was totally rusted out and you could only really see this when you had pulled it off.
hope this helps.
[Updated on: Thu, 12 December 2002 09:12]
ZZT231
melbourne.vic.au
Re: HELP! MA61 Overheating Thu, 12 December 2002 14:47 Go to previous messageGo to next message
That is great!
Thanks for the reply guys. I am keeping the Fluid Couple Fan and going to replace it hopefully by Saturday.
I am keeping it because going Thermos is too much messing around.
My Pump is Working Fine, I had the system Pressure tested and passed with Flying colours. Its just the fan Mad
Cheers.
Corvid
Re: HELP! MA61 Overheating Thu, 12 December 2002 20:50 Go to previous messageGo to next message
Hey mate,
i think i have one these off a 5m at home..
Email me.. im in sydney
Corvidcee@hotmail.com
ZZT231
melbourne.vic.au
Re: HELP! MA61 Overheating Sat, 14 December 2002 07:47 Go to previous messageGo to next message
Just replaced the water pump, Fan and a full flush out of the radiator.
Greater trouble is that i may have damaged head i think or done a gasket though my oil is not going milky and either is the radiator fluid.
At the moment i loose a lot of radiator fluid through the reserve and when i run the car. With the radiator cap off i can see the water bubbling air.
Can anyone elaborate what is wrong...
SupraBOY
Yeppoon/Rockhampton
Re: HELP! MA61 Overheating Sat, 14 December 2002 09:40 Go to previous messageGo to next message
when you change your radiator fluid you should have the car running and keep topping the radiator levels up. place your hand over where the radiator cap would go and hold it down for 10 secs. then take it off. bubbles should come out... do this for about 5 - 10 mins.
this way you get all your bubbles out of the water system.
keep your overflow thingi at 1/2 level.
PayneyCelica18rg
Southport
Re: HELP! MA61 Overheating Sat, 14 December 2002 23:48 Go to previous messageGo to next message
did you know that because electric fans are not hanging off your crank, they can save you a few kW. and so can electric fuel and water pumps. Actuallt the less shit you have attached to fan belts the better. When i raced of road, i didn't even bother with the altinator during short course events, cause you could recharge while waiting. so i really would go electric... It could mean the difference between that falcon blowing you away, or you putting the nose infront of him... but hey, up to you.
[Updated on: Sat, 14 December 2002 23:51]
SupraBOY
Yeppoon/Rockhampton
Re: HELP! MA61 Overheating Sun, 15 December 2002 10:21 Go to previous messageGo to next message
i enquired about getting thermo fans for my radiator. but the guys said not to worry about it as the fan works off a clutch. it's not spinning all the time so doesn't use any extra power.
PayneyCelica18rg
Southport
Re: HELP! MA61 Overheating Sun, 15 December 2002 10:36 Go to previous messageGo to next message
the guy who said the clutch fan doesn't use extra power was only giving half the story.
Of course when the engine is cool, the fan does not spin, these fans can either be fulid filled, or a temperature controlled spring. both do the same thing, when the temp rises, the fan is made to spin and at this point, there is now (minimal but) extra load...
so unless your fan knows it is time to race, (chances are you've been cruising round for the right falcon/holden/torana/escort/excel/lancer to blow, on the right strip of road), the cluch fan is engaged when it comes time to drop the clutch.
Tell the guy that explained clutch fans to you that next time he should tell the whole story. the fact is and i'm not being rude, just a smart ass, anything attached to the motor via a fan belt uses power. but if you aren't out to beat anyone, sure stick to the fan, I wouldn't.
Re: HELP! MA61 Overheating Sun, 15 December 2002 23:54 Go to previous messageGo to next message
Has it occured to you that an electric fan also places a load on the engine? Sure it's not directly attached to the crank, but it uses a fair amount of juice. And guess where that power comes from? The alternator, that's where!
Re: HELP! MA61 Overheating Mon, 16 December 2002 00:05 Go to previous messageGo to next message
ZZT231 wrote on Sat, 14 December 2002 18:47
BHG..... Crying or Very Sad
PayneyCelica18rg
Southport
Re: HELP! MA61 Overheating Mon, 16 December 2002 03:08 Go to previous message
Norbie wrote on Mon, 16 December 2002 10:54
Yes, but it is a much smaller load... I have read this in mags. and everything you read is true... but note earlier i did mention the alternator, and said when i raced, i took it out.
but look, don't listen to me, the guy's replaced the clutch fan anyway.
Previous Topic:16v to 20v
Next Topic:Resetting the Toyota ECU
Current Time: Sat Oct 31 18:46:06 UTC 2026
Total time taken to generate the page: 0.01134204864502 seconds
