Toymods » Tech & Conversions » Diff troubles RA23
Sleeka76
Brizvegas
July 2005
Diff troubles RA23 Tue, 19 July 2005 07:11 Go to next message
Hi all, I've just been chasing diff centres for my 23 can't seem to find one anywhere, closest i can get is a RA40. was wondering if they where the same centre or not? Also wondering if there was a difference in ratio between auto and manual? Contemplating complete swap I.E:Hilux\Corona Which is easiest? Thanx for your help Wink
stradlater
Arthurs Creek, Victoria
Re: Diff troubles RA23 Tue, 19 July 2005 07:18 Go to previous messageGo to next message
I went hilux. Heavy as hell (relative) but you won't break it unless your using a nitro glycerine fuelled twin supercharged V12 or something. You'll break other stuff first (as I've found).
Really does bring a new meaning to "Unbreakable"
KiRK
Re: Diff troubles RA23 Tue, 19 July 2005 07:23 Go to previous messageGo to next message
RA40 centers will fit fine... I had one in my RA28 before I swapped the whole diff out for a hilux unit.
Sleeka76
Brizvegas
July 2005
Re: Diff troubles RA23 Tue, 19 July 2005 07:24 Go to previous messageGo to next message
Was there much messing about to fit the diff? What model did you use?
KiRK
Re: Diff troubles RA23 Tue, 19 July 2005 07:30 Go to previous messageGo to next message
Are you talking about the diff center or the whole assembly? I only fitted the center and it's a direct bolt in.
stradlater
Re: Diff troubles RA23 Tue, 19 July 2005 07:34 Go to previous messageGo to next message
RN25 Hilux Diff (2 wheel drive)
I didnt' install it, but the axles didn't need to be shortened, and the mounts did need to be cut.
Not a home brew job.
Sleeka76
Brizvegas
July 2005
Re: Diff troubles RA23 Tue, 19 July 2005 07:37 Go to previous messageGo to next message
Just spoke to a few wreckers this afternoon and could get RA40 diff centre pretty easily and cheaply ($110) but the option of a hilux diff was on the cards. Can quite easily get one for around $250 (75 model) is there much difference across the range 72-85?
stradlater
Re: Diff troubles RA23 Tue, 19 July 2005 07:39 Go to previous messageGo to next message
Fuck, if that 75 model is a 2wd and it's an RN2x then for $250 I'd be jumping at the opportunity.
Sleeka76
Brizvegas
July 2005
Re: Diff troubles RA23 Tue, 19 July 2005 07:40 Go to previous messageGo to next message
Did that set you back much casholla? Nice picks on your sight by the way Cool
Sleeka76
Brizvegas
July 2005
Re: Diff troubles RA23 Tue, 19 July 2005 07:46 Go to previous messageGo to next message
Was that a direct bolt in for the RA40 or the 'G' series that you put in ? was there any difference in ratio between the 40 and the 23?
KiRK
Re: Diff troubles RA23 Tue, 19 July 2005 08:05 Go to previous messageGo to next message
My RN25 set me back $850 with an LSD center.... So if you found one for $250 and it is definately a RN25 / 27 Hilux... BUY IT!
stradlater
Re: Diff troubles RA23 Wed, 20 July 2005 01:22 Go to previous message
I second Kirk on that one.
You'd absolutely die if you heard what I paid.
I paid
$1000 for an rn25 with diff (got about $200 back on parts for the heap of shit)
Paid $250 for a new LSD center
then installation was hella expensive. Seriously, if you have the ability to get an rn25 diff for $250, I wouldn't still be here on the net.
And btw, thanks for the kudos on the site, I hope that you like it. I should have more photos of the diff, I'll maybe do that on the weekend.
Previous Topic:Where to mount the ECU
Next Topic:VVTI on 20vs
Current Time: Thu Nov 19 21:39:55 UTC 2026
Total time taken to generate the page: 0.0068271160125732 seconds
