Toymods » Tech & Conversions » Audio help
shezza
Melbourne, Victoria
March 2005
Audio help Tue, 19 July 2005 07:24 Go to next message
I have one of the units that u connect your sound to and your neons and they go to the beat. Now the rca cables have two wires in each cable (one on the outside and one in the centre). I only have two holes on the curcuit board. WHich wires would go into those two holes. Any help would be appreciated Smile
setsuna
Re: Audio help Tue, 19 July 2005 07:46 Go to previous messageGo to next message
shouldn't matter which way they go Smile
Aust162
Melb, Victoria
Re: Audio help Tue, 19 July 2005 08:07 Go to previous messageGo to next message
either way should work. you might end up reversing the polarities, but thats ok.
shezza
Melbourne, Victoria
March 2005
Re: Audio help Tue, 19 July 2005 14:36 Go to previous messageGo to next message
So I only use one rca cable and use the two wires off it (which doesnt seem to be working) or do I use both cables and in each cable mix the 2 wires together?
feral4mr2
Bundaberg, Qld.
Re: Audio help Tue, 19 July 2005 22:33 Go to previous messageGo to next message
the outer wire in the RCA cable is basicaly the - output signal and the inner wire the + output signal. in an audio situation you dont want to mix them up as reversing the polarity does effect the sound of your system.
i've never used a neon set-up that beats with the music, did it come with any diagrams?
shezza
Melbourne, Victoria
March 2005
Re: Audio help Wed, 20 July 2005 05:44 Go to previous messageGo to next message
Yea everything seems ok but they wont go to the beat, they are just steady. COnsidering I only have 2 input holes I used the + off one rca and a - off the other, this sound right?
feral4mr2
Bundaberg, Qld.
Re: Audio help Wed, 20 July 2005 08:47 Go to previous messageGo to next message
by the sounds of how it must get it's signal, i would only wire 1 rca lead to it. joining the 2 rca's together could fry the output chip in the head unit.
shezza
Melbourne, Victoria
March 2005
Re: Audio help Wed, 20 July 2005 09:46 Go to previous messageGo to next message
feral4mr2 wrote on Wed, 20 July 2005 18:47
Will it understand when to go on and off properly?
Maybe I should intertwine the - and + from each cable ...?
[Updated on: Wed, 20 July 2005 10:20]
feral4mr2
Bundaberg, Qld.
Re: Audio help Wed, 20 July 2005 11:15 Go to previous messageGo to next message
i dunno exactly, it must work off the voltage pulse or something the head unit puts out through the RCA lead. been too long since i've done this sort of thing theory wise.
as i said above, you would find that would fry the output chip in your head unit. that would be like crossing all the speaker output wires from your head unit together.
shezza
Melbourne, Victoria
March 2005
Re: Audio help Thu, 21 July 2005 11:16 Go to previous messageGo to next message
So u are quite sure than that one channel is the way to go?
setsuna
Re: Audio help Thu, 21 July 2005 11:42 Go to previous messageGo to next message
damn right.
(or we could be saying this to make the whole thing BLOW UP IN YOUR FACE)
are your subs mono? Razz
shezza
Melbourne, Victoria
March 2005
Re: Audio help Thu, 21 July 2005 11:56 Go to previous message
setsuna wrote on Thu, 21 July 2005 21:42
damn right.
Well I guess I have to trust u Rolling Eyes
Im actually using the front speakers out caus I dont have a sub out and my rear out is connected to an amp.
Previous Topic:1UZFE + TROOP CARRIER
Next Topic:auto to manual, 88 1ggte soarer
Current Time: Fri Nov 20 07:38:22 UTC 2026
Total time taken to generate the page: 0.035952806472778 seconds
