Toymods » Tech & Conversions » St-185RC Water To Air Intercooler, hows it work?
LeaThaL
Brisbane, Queensland
June 2005
St-185RC Water To Air Intercooler, hows it work? Tue, 19 July 2005 11:05 Go to next message
hey guys,
i got myself a st-185RC 3s-gte motor im using for a conversion, were gettin closer to having it finished but what is puzzing me is how the water to air intercooler setup works, what the red liquid that was inside mine was and if its always pumping everything thru then how does it say outta the throttle body and turbo? :S
any info is helpful as im a mech appencitce Razz thanks guys
tricky
July 2005
Re: St-185RC Water To Air Intercooler, hows it work? Tue, 19 July 2005 12:32 Go to previous messageGo to next message
Not specific to ST185RC ('cos I dunno), but a generalisation of W-A intercoolers.
The red liquid is coolant. Exactly the same as in the radiator. The reason the coolant doesn't go in to the inlet is because it is isolated. There is no direct contact between the inlet charge and the coolant. Basically the intercooler consists of the inlet pipe runnning through a jacket of coolant. This coolant goes through the heat exchanger in the front bar, which is essentially the same as a radiator. So the inlet temps are controlled by the cooler, and the coolant is chilled by the heat exchanger.
feral4mr2
Bundaberg, Qld.
Re: St-185RC Water To Air Intercooler, hows it work? Tue, 19 July 2005 23:05 Go to previous messageGo to next message
did a quick google, not the best stuff but a few things that may help.
http://www.alltrac.net/tuning/intercooler.html
http://autospeed.drive.com.au/cms/A_0090/article.h tml
http://www.conleyracing.com/article_intercooler.ht m
http://www.bellintercoolers.com/Pages/LiquidToAir_ intro.asp
[Updated on: Tue, 19 July 2005 23:06]
Toobs
Re: St-185RC Water To Air Intercooler, hows it work? Tue, 19 July 2005 23:26 Go to previous messageGo to next message
Think of a water to air IC as two radiators, one which is encapsulated (heat exchanger) and one not.
The water flows around the two radiators via a moderately sized water pump.
The heat exchanger works in reverse to the way a normal radiator works, the water actually cools the charge air instead of the air cooling the water.
The main radiator is then cooled by air in a normal fassion.
LeaThaL
June 2005
Re: St-185RC Water To Air Intercooler, hows it work? Wed, 20 July 2005 07:34 Go to previous messageGo to next message
so what does filler cap on the IC only fill the core? cause you can see in and out of the inlet pipe from the turbo and to the throttle inlet :S
davedave
Re: St-185RC Water To Air Intercooler, hows it work? Wed, 20 July 2005 07:40 Go to previous messageGo to next message
Yep, it fills the water part.
You will also notices there's two much smaller pipes coming from the intercooler. These lead to the heat exchanger (another radiator) and the pump.
LeaThaL
June 2005
Re: St-185RC Water To Air Intercooler, hows it work? Wed, 20 July 2005 07:43 Go to previous message
yeah i figured that one when i dismantled it all Razz, thanks for all the info guys its been a great help Smile but still if you know other stuff on it feel free to msn me or pm or just post here Razz im always up for a chat Razz
Previous Topic:1G-GTE TPS, what other car uses it?
Next Topic:4agte computer
Current Time: Thu Nov 19 11:35:39 UTC 2026
Total time taken to generate the page: 0.013622999191284 seconds
