Toymods » Tech & Conversions » 1G-GTE throttle body upgrade?
VeeP
May 2005
1G-GTE throttle body upgrade? Tue, 19 July 2005 15:06 Go to next message
Hey everyone
does anybody know of a bolton or minimal modification throttle body upgrade for a 1G-GTE?
[Updated on: Tue, 19 July 2005 15:07]
stradlater
Arthurs Creek, Victoria
Re: 1G-GTE throttle body upgrade? Wed, 20 July 2005 01:14 Go to previous messageGo to next message
A Gas Research throttle body will bolt on nicely, it's huge and it comes in lots of different colours.
KiRK
Re: 1G-GTE throttle body upgrade? Wed, 20 July 2005 02:22 Go to previous messageGo to next message
Would be interesting to see what is available... besides LPG Very Happy
stradlater
Re: 1G-GTE throttle body upgrade? Wed, 20 July 2005 02:52 Go to previous messageGo to next message
Is there anything else beside LPG??
KiRK
Re: 1G-GTE throttle body upgrade? Wed, 20 July 2005 03:05 Go to previous messageGo to next message
In your case... no Very Happy
hickoz_bro
Re: 1G-GTE AFM upgrade? Wed, 20 July 2005 03:09 Go to previous messageGo to next message
what about the AFM??? are there any less restrictive alternatives?
Re: 1G-GTE throttle body upgrade? Wed, 20 July 2005 03:38 Go to previous messageGo to next message
VeeP wrote on Wed, 20 July 2005 01:06
silly response: the only response to michael bolton is to STFU or die!
seriously: the incoming flow-restrictions are in the AFM and sub-sized piping - enlarge the piping and change to a MAP-based engine management. This requires little if any modification of the TB but substantial damage to your wallet.
Merudo
Central Coast, NSW
February 2005
Re: 1G-GTE throttle body upgrade? Wed, 20 July 2005 03:42 Go to previous messageGo to next message
so once you've changed to some aftermarket engine management with a MAP setup instead of AFM, and you've got some larger piping, are you saying that makes a difference straight away?
Or rather it provides the potential for more of a difference?
hickoz_bro
/me thinks AFM => MAP conversion means new ECU too??? = $
Merudo
Central Coast, NSW
February 2005
Re: 1G-GTE throttle body upgrade? Wed, 20 July 2005 03:45 Go to previous messageGo to next message
hickoz_bro wrote on Wed, 20 July 2005 13:42
Nod Nod
hickoz_bro
Re: 1G-GTE throttle body upgrade? Wed, 20 July 2005 03:48 Go to previous messageGo to next message
/me thinks the AFM set up blows...
why can't they just take a sample of the air flow (divert a small amount of flow) restrict that, measure the air flow volume/speed, and let the rest go on like a happy little vegemite?
Re: 1G-GTE throttle body upgrade? Wed, 20 July 2005 03:51 Go to previous messageGo to next message
Merudo wrote on Wed, 20 July 2005 13:42
the later - it provides you with:
tunable ECU (rather than blindly tinkering with the AFM)
elimination of obvious flow restrictions
you could put an aftermarket ECU (or a $300 megasquirt ECU like i'll do) on and get less power - the effort will be in the tuning and improvements to induction - then you can focus on stuff like turbo(s), cams, zorst, etc
stradlater
Re: 1G-GTE throttle body upgrade? Wed, 20 July 2005 03:53 Go to previous messageGo to next message
Because it needs to know EXACTLY how much air is going in.
Your not going to get rid of the AFM without changing the ECU.
That said.....
There are a great many things that can and should be changed prior to upgrading the throttle body and POST upgrading the ECU..
I have only changed mine for just a FEW obvious reasons.
TOY77
Re: 1G-GTE throttle body upgrade? Wed, 20 July 2005 07:40 Go to previous messageGo to next message
hi there
i think you will find that an xf throttle body fits. i am pretty sure it is a bolt on... same bolt pattern.
Stew
dispatcher
Malaysia,Kuala Lumpur
Re: 1G-GTE throttle body upgrade? Wed, 20 July 2005 08:07 Go to previous messageGo to next message
Pardon ME Sir...XF ? What type of car are you referring to please.
TOY77
Re: 1G-GTE throttle body upgrade? Wed, 20 July 2005 08:12 Go to previous messageGo to next message
hi,
xf falcon
stew
EvilJack
Sutho/Hills NSW
Re: 1G-GTE throttle body upgrade? Wed, 20 July 2005 08:13 Go to previous messageGo to next message
try and get the plug for the tps also
stradlater
Re: 1G-GTE throttle body upgrade? Thu, 21 July 2005 02:14 Go to previous messageGo to next message
The XF Falcon TB will fit, HOWEVER. THe TPS that comes with it won't be a 'plugin' option for the toyota management I don't think.
It'll be more of a "Plug and Pray" scenario.
Fattony
Re: 1G-GTE throttle body upgrade? Thu, 21 July 2005 03:38 Go to previous messageGo to next message
Ok firstly, if you want to test the restrictiness of the afm, hook up a manometer before and after the afm, and see the difference in inches of water and you can then convert that back to a reletive psi drop accross the afm. Secondly there is absolutly no fucking need to change the t/body to a larger item if you a) are using stock ecu b) using stock turbos c) stock cooler, ect, you will never see the benefit with any stock components being changed or modified. That said a XF t/body will line up with the bolt holes perfectly, but dont do wat some dickheads do and not bore out the hole in the plenum to suit, you will cost yourself performance that way. But dont always think a bigger t body is better, its all relative to the power ouput and capacity of a motor, just like exhaust size. With a aftermarket ecu you would have no problem using the ford tps either Wink
stradlater
Re: 1G-GTE throttle body upgrade? Thu, 21 July 2005 04:03 Go to previous messageGo to next message
Didn't say you'd have a problem with the ford TPS with an aftermarket ECU, it's only the standard ECU that would cause problems.
hickoz_bro
Re: 1G-GTE throttle body upgrade? Thu, 21 July 2005 23:34 Go to previous messageGo to next message
what advantages does the XF TB offer over the stock TB? just larger bore? or is there more to it?
stradlater
Re: 1G-GTE throttle body upgrade? Fri, 22 July 2005 00:36 Go to previous messageGo to next message
Larger bore and larger butterfly. But seriously man, Fattony is absolutely right. THere are SOOOO many things you should change before the factory TB anyway....
hickoz_bro
Re: 1G-GTE throttle body upgrade? Fri, 22 July 2005 00:38 Go to previous messageGo to next message
ahhhh no doubt, i got no intentions to change the stock TB... i think the AFM would be one of the first things i'd like to see go
stradlater
Re: 1G-GTE throttle body upgrade? Fri, 22 July 2005 01:36 Go to previous messageGo to next message
Seriously, it's costly but aftermarket management will change the possibilities endlessly. The amount of fucking around you'll have to do with stock management is just fuckgin silly.
hickoz_bro
Re: 1G-GTE throttle body upgrade? Fri, 22 July 2005 01:38 Go to previous messageGo to next message
of course... first on my list of things to do is.... get engine running Rolling Eyes
stradlater
Re: 1G-GTE throttle body upgrade? Fri, 22 July 2005 01:53 Go to previous messageGo to next message
Get engine running, with standard management := Time and headache + probably (wasted) money
Get engine running with aftermarket management := Bit more time, less headache for sure, and money, but not wasted..
Do it once, do it right, or don't complain.
hickoz_bro
Re: 1G-GTE throttle body upgrade? Fri, 22 July 2005 02:03 Go to previous messageGo to next message
*ahem* get the stock engine running, with stock ECU, and stock AFM, stock TB, ie... get it running first time... i'll start with stock, modify it when money allows...
stradlater
Re: 1G-GTE throttle body upgrade? Fri, 22 July 2005 02:06 Go to previous messageGo to next message
Best of luck with the Stock ECU and Stock Loom, into your Stock RA28.. But ok, if you want..
Been there, done that. Will require modification.....
hickoz_bro
Re: 1G-GTE throttle body upgrade? Fri, 22 July 2005 02:08 Go to previous messageGo to next message
and less money for the moment... lol... i'm just a poor uni bum... leave me alone Laughing
stradlater
Re: 1G-GTE throttle body upgrade? Fri, 22 July 2005 02:09 Go to previous messageGo to next message
It may appear like less money at the time...
TOY77
Re: 1G-GTE throttle body upgrade? Fri, 22 July 2005 11:22 Go to previous message
go the stock management.
it is a piece of piss to get up and runnin.
the stock management does alot better than most people give it credit for.
my 28 has run a 12.5 sec 1/4 @ 110.9MPH on factory management so dont be afraid to have a go.
Stew
Previous Topic:20v head gasket
Next Topic:timing chain guides & tensioner query, 3T vs 18RG
Current Time: Tue Oct 27 12:40:48 UTC 2026
Total time taken to generate the page: 0.12976408004761 seconds
