Toymods » The Outhouse » Java Problems
nightdevil
Wollongong
Java Problems Wed, 20 July 2005 05:43 Go to next message
Im having a problem with IE6 browser. When a Java applet is about to load i get a little window that pops up (Title = asdas) and in the window it says "register failk" I click Ok to this window and it pops up several more times then i get this message:
Cannot load class sun/plugin/JavaRunTime.
The Bridge was installed at <C:\PROGRA~1\Java\J2RE14~1.1_)>but the class is not there
Modify the registry key to reflect the new bridge location
The key is HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Plug-in
or change your CLASSPATH to include the new directory
Please consult the documentation for more information
Does anybody know how to fix this problem?
Much appreciated
Craig
EvilJack
Sutho/Hills NSW
Re: Java Problems Wed, 20 July 2005 06:26 Go to previous messageGo to next message
get firefox
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: Java Problems Wed, 20 July 2005 06:36 Go to previous messageGo to next message
Do you know where your J2RE is installed? If you do, then:
right click on My Computer
select Properties
Choose the Advanced tab
click on Environmental Variables
find the variable called CLASSPATH and add the location of your J2RE in there... Make sure you put a semi-colon ( ; ) in between the new path and whatever is existing in there........
Hope that makes sense.
hamgatan
Re: Java Problems Wed, 20 July 2005 07:03 Go to previous messageGo to next message
yeah im with him <<<--
that error message means you have had java virtual machine installed at some stage (and now for some reason it aint there!) whether it uninstalled incorrectly or just got deleted manually or whatever..
reinstalling sun java virtual machine should put everything back into place and fix the registry entries properly..
nightdevil
Wollongong
Re: Java Problems Wed, 20 July 2005 11:14 Go to previous message
Thanks guys
Im downloading Java 2 SDK, Standard Edition 1.4.2_08, so i'll see how that goes
Previous Topic:A better Toyota ad
Next Topic:Why didnt VET remove this shizet?? VIrus Q
Current Time: Sun Nov 22 18:39:50 UTC 2026
Total time taken to generate the page: 0.010668992996216 seconds
