Toymods » Tech & Conversions » Oxygen Sensor
TreunoGTV
Oxygen Sensor Wed, 20 July 2005 13:06 Go to next message
Can someone tell me the colours of the 4 wires that connect up to the oxygen sensor from the harness for my DLi 4agze.
I already know B-W is from the ECU.
TreunoGTV
Re: Oxygen Sensor Thu, 21 July 2005 07:21 Go to previous messageGo to next message
bump
ozzy31
Edmonton, AB
June 2005
Re: Oxygen Sensor Thu, 21 July 2005 20:45 Go to previous messageGo to next message
I can't imagine this is of any value to you, I wouldn't know about yours...
But here is the wire setup on a hilux 4-wire... at least here in Canada/USA...
sensor... harness... purpose...
blue... black... sensor signal to ecu
white... brown... sensor ground
black... white/red... heater 12v+
black... pink/green... heater, ecu
Good luck
LeZZa
Re: Oxygen Sensor Fri, 22 July 2005 13:42 Go to previous messageGo to next message
There is a grey one that is shielded, I can't remember the others. You can get the wiring diagram for the 4agze ECU from club 4ag.
I'll check my car if you still need to know.
20VBTSECA
May 2005
Re: Oxygen Sensor Fri, 22 July 2005 14:44 Go to previous message
pretty sure the sheilded wire is your ox wire.
black is your ground
two white ones are your heater ones
best thing to do is to map them out with your multimeter from your ECU to the wire under the car. Thats how I did my blacktop oxy as the motor didnt even come with a plug for it.
if your really stuck try emailing hsvmaloo_r8@hotmail.com (rhys) he has a 4agze in his ae92 seca and he knows quite allot about them.
Not sure if this will do the same with the gze but my age needed the ECU to be reset (disconnecting (-) from the battery for 20 seconds)
dan.
[Updated on: Fri, 22 July 2005 14:50]
Previous Topic:Boosted 3TC.
Next Topic:What car does a W55 come out of?
Current Time: Thu Oct 29 14:50:00 UTC 2026
Total time taken to generate the page: 0.0064017772674561 seconds
