Toymods » Tech & Conversions » Alternative alternator bracket for 4AG?
jkvsnn
Alternative alternator bracket for 4AG? Wed, 20 July 2005 13:24 Go to next message
Here's the thing.
Have 20VST, for reasons of space I can't use std alternator. I have found a suitably small alternator (1kg lighter too Evil or Very Mad ) from a petrol 2Y Dyna that fits except that the distance between the mounting bolts for is 6.5mm closer for the Dyna alternator. Does anyone know if the top alternator bracket from other 4A's are interchangable (or even different?) with the 20V one?
why have i bothered typing this out...nobody is going to know this...
Julian.
._T_.
Re: Alternative alternator bracket for 4AG? Wed, 20 July 2005 22:46 Go to previous messageGo to next message
with conversions you generally remake something - for instance the diahatsu & suzuki alternators are made by the same company that makes them for toyota, just smaller. mounts can be easily modified
cut & reweld the tensioner bracket to suit you new installation i suggest.
T
jkvsnn
Re: Alternative alternator bracket for 4AG? Wed, 20 July 2005 23:13 Go to previous messageGo to next message
Thanks T,
I had anticipated having to redo the bracket but thought I might throw the question out there...just in case.
Julian
Salad Fingers
Darwin, Australia
March 2005
Re: Alternative alternator bracket for 4AG? Thu, 21 July 2005 00:56 Go to previous messageGo to next message
Not sure what the 20v are like, but on my rwd big port I used a different alternator which had different mounting distance between ears.
All i did was, since the rwd adjustment mount has two bolts holding it to the block, you just slot one (you could even do it to both) of the bolt holes in the adjuster and adjust it that way.
Works perfectly here. Smile
jkvsnn
Re: Alternative alternator bracket for 4AG? Thu, 21 July 2005 03:09 Go to previous messageGo to next message
Thanks Salad for the reply but I can't quite picture what you mean, got a photo?
Julian
Salad Fingers
Darwin, Australia
March 2005
Re: Alternative alternator bracket for 4AG? Thu, 21 July 2005 06:50 Go to previous message
No photo but i just drew up a _very_ crude drawing of what i'm barking about.
http://users.bigpond.net.au/iwantagtir/images/alt.jpg
Again i'm not sure if this is applicable to your 20v setup, this what the rwd bracket looks like though.
Personally I just drilled them out bigger and then used some larger washers and just did the bolts up again. Works perfectly.
[Updated on: Thu, 21 July 2005 06:51]
Previous Topic:blacktop conversion .... where???
Next Topic:Whats Your 4 Spot Calliper?
Current Time: Fri Nov 20 10:25:06 UTC 2026
Total time taken to generate the page: 0.0079309940338135 seconds
