Toymods » Tech & Conversions » RA60 gear box
battlestar
June 2005
RA60 gear box Thu, 21 July 2005 06:12 Go to next message
can anyone tell me if a ra60 gear box is the ratio and stick position i need to suit ae86
wilbo666
Re: RA60 gear box Thu, 21 July 2005 06:20 Go to previous messageGo to next message
yep, i can do that...
go to the top right hand corner of this page...and there is a link that says "SEARCH"...follow that link Smile
if that doesn't help you to find the ratios in your gearbox you will need to know it gearbox code it will be one of W55, W57 or W58 . You can get this from the ID plate in the engine bay, however if the gearbox has been swapped in the past this may be incorrect...
anyway do a search...Smile
edit: my comments may be a bit rough, at first glance it looked like your were asking what the ratios of the RA60 box were...when at later inspection you may be asking if the ratios in that box will suit an ae86...
If it helps off the top opf my head the T50 ratios are damm close to the W55 ratios... the W57/W58 ratios are slightly longer? (i can never remember if the terminology is shorter or longer Smile)
Anyway I'd just choose a rear end ratio to suit your diving style and car use, rather than choosing the gearbox...
[Updated on: Thu, 21 July 2005 06:31]
Re: RA60 gear box Thu, 21 July 2005 06:30 Go to previous messageGo to next message
wilbo666 wrote on Thu, 21 July 2005 16:20
edit: this may seem a bit rough, at first glance it looked like your were asking what the ratios of the RA60 box were...when at alter inspection you may be asking if the ratios in that box will suit an ae86...
and of course if the ratios are unsuitable then wilbo's home for unwanted W-series gearboxes would be more than willing to accept these unwanted orphans of the toyota world Laughing Very Happy Very Happy
wilbo666
Re: RA60 gear box Thu, 21 July 2005 06:33 Go to previous messageGo to next message
thechuckster wrote on Thu, 21 July 2005 16:30
Ouch! Embarassed Embarassed Embarassed
Razz it is true tho Wink
battlestar
June 2005
Re: RA60 gear box Thu, 21 July 2005 06:42 Go to previous messageGo to next message
thanks champ so is the ra 60 box a w55 and can u tell me stick position in the car and best bell housing kit our know of one for sail
wilbo666
Re: RA60 gear box Thu, 21 July 2005 06:51 Go to previous messageGo to next message
battlestar wrote on Thu, 21 July 2005 16:42
I think they have the option of W55, W57 and W58?...not 100% sure on that, someone that has/or has had a RA60 in the past may shed more light on that.
If you do a search Wink you will find a picture showing the 4 different shifter positions that the alloy cased gearboxes can come in... the RA60,RA65 and MA61 have the second shifter position from the right which is the second closest to the front of the car avaliable. I have no idea what shifter position is required for a AE86.
Have a search Wink in the forsale section and you will find a number of 4a -> w5x bellhousings that have been offered in the past and currently I believe.
V8_MA61
Re: RA60 gear box Thu, 21 July 2005 09:23 Go to previous messageGo to next message
early 55,57 and 58 are identical bar the 58 has a longer overdrive.
They ALL look identical, and ALL have alloy sandwich plates
Re: RA60 gear box Thu, 21 July 2005 12:44 Go to previous messageGo to next message
Far as I know, the RA60s all have '57s, SA63s have '55s, and RA65s have '57s?
Re: RA60 gear box Thu, 21 July 2005 12:56 Go to previous messageGo to next message
i'd say that a combination of reading Ed's gearbox research, noting down the trans code from the car's ID plate, looking at the thing and (if you have time to waste) carefully counting rotations on the input& output shafts for different gears you should be able to identify the box accurately.
see here <http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/Gearboxes.html> for data needed to help calculate ratios.
search for 'gearbox' for the other stuff.
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: RA60 gear box Thu, 21 July 2005 14:27 Go to previous message
RA65s got W55s and 58s afaik. Only the ra60 copped the W57.
Previous Topic:Leads and Plugs for 5fse
Next Topic:RA28 Diff
Current Time: Sun Oct 25 08:09:28 UTC 2026
Total time taken to generate the page: 0.0060379505157471 seconds
