Toymods » Tech & Conversions » Fitting a Shif light to a 4agze with coil packs
adavy84
Perth, WA
Fitting a Shif light to a 4agze with coil packs Thu, 21 July 2005 11:12 Go to next message
Hey, Ive got this shif light and as my 4agze is coil packs im not sure where to connect it to. Can i use the tacho output on the ECU. and what pin would it be?
Cheers.
sideshow
Re: Fitting a Shif light to a 4agze with coil packs Thu, 21 July 2005 12:08 Go to previous messageGo to next message
theres no tacho output on the ecu just connect it to ig- on the diag plug
adavy84
Perth, WA
Re: Fitting a Shif light to a 4agze with coil packs Thu, 21 July 2005 15:11 Go to previous messageGo to next message
ok cool.
Re: Fitting a Shif light to a 4agze with coil packs Fri, 22 July 2005 05:02 Go to previous messageGo to next message
sideshow wrote on Thu, 21 July 2005 22:08
WTF!?!?!
What would you consider IGt to be then?
There is also the IG- on the diagnostic plug, which is the tacho output wire from the Ignitor, but IGt would be a little easier to get to... well for me anyway Smile
sideshow
Re: Fitting a Shif light to a 4agze with coil packs Sat, 23 July 2005 09:01 Go to previous message
that is the signal to the ignitor
i never use it incase it get interference to ignitor
just much less hassle using the proper rpm signal form the ignitor
Previous Topic:How to install AE112 CD Player
Next Topic:100kw into ae82 wiring
Current Time: Fri Nov 20 01:44:43 UTC 2026
Total time taken to generate the page: 0.0058760643005371 seconds
