Toymods » Tech & Conversions » supra timing problems
Stomps
Canning Vale WA
icon9.gif  supra timing problems Thu, 21 July 2005 11:44 Go to next message
hey ppls just put a steel head gasket into 7m-gte, did everything properly etc.. set up timing according to tech manual but the car is running like a hairy goat.. i havn't got on boost yet coz still running it in but down low it feels really sluggish, feels like clutch slip, the revs are there but the car aint accelerating (its not the clutch)..
any help would be appreciated.. cheers
Jurek
Re: supra timing problems Thu, 21 July 2005 11:53 Go to previous messageGo to next message
did you do the timing 180 degrees out? Smile
checked it with a timing light?
other thing that can cause similar symptoms (tho usually not that severe) is a vac hose not connected - double check that.
Stomps
Canning Vale WA
Re: supra timing problems Fri, 22 July 2005 04:14 Go to previous messageGo to next message
yeah i checked with timing light, its all good.. normally with vacuum hoses it starts to run really rich and almost stall.. had that before, it seems to be something else.. i will double check all hoses anyway, cheers mate
Re: supra timing problems Fri, 22 July 2005 06:14 Go to previous messageGo to next message
My car had similar symptoms when I wired up the cam sensor the wrong way around... but I don't know if the 7m even uses a cam sensor.
(I'm just throwing in whatever could cause those symptoms, I'm kinda stumped)
Re: supra timing problems Fri, 22 July 2005 06:47 Go to previous messageGo to next message
Cam belt off by a tooth? Check and double-check, it's a bitch to get it right!
Stomps
Canning Vale WA
Re: supra timing problems Fri, 22 July 2005 07:00 Go to previous message
yeah its got a cam angle sensor, i lined it up like it said might have gotten it wrong though.. timing belt seems ok.. will have to check it all again... i love dealing with the timing Mad Mad Mad
Previous Topic:W5X short shifter designs
Next Topic:RA65 exhaust size.
Current Time: Sun Oct 25 06:46:17 UTC 2026
Total time taken to generate the page: 0.0044779777526855 seconds
