Toymods » Tech & Conversions » Sprinter suspension bushings
Callifo
Gawler, SA
Sprinter suspension bushings Thu, 21 July 2005 13:21 Go to next message
Did a search and cant find a list of all the bushings so just wondering if there are any bushings missing, as I was looking at what toyota can supply in hard rubber.
They can do:
Front and rear sway bar bushes
Front ctrl arm bushes
Stabilizer bar bushes
Rear lateral rod bushes
for $300.
BTW: Looked at polyurethane ones but from what people have said they only have a few years of life before they start to crack. Unless thats untrue.... these toyota parts are same price as ones supplied by auto stores.
Re: Sprinter suspension bushings Thu, 21 July 2005 23:29 Go to previous messageGo to next message
Radius rods
Trailing arms
cri_ag
northern beaches
Re: Sprinter suspension bushings Fri, 22 July 2005 08:29 Go to previous messageGo to next message
d-d-double p-p-ost
[Updated on: Fri, 22 July 2005 09:12]
cri_ag
northern beaches
Re: Sprinter suspension bushings Fri, 22 July 2005 08:49 Go to previous messageGo to next message
i was told by a suspension guy that alot of the time pollyurethane bushes crack because they havent been installed properly, for example the special grease that is supplied with most of the kits is not applied correctly or at all.
another reason he gave was that when the bushes are installed the suspension components are usualy at full droop, ie. the car is jacked up of the body, you then procede to tighten all the components up and when the car is lowered to the ground the bushes are sitting in tension instead of in their natural position. So every bump after that tensions them even more hence causing premature failure (cracking).
that was his explanation, he suggested doing every thing up finger tight then dropping the car to the ground and torquing everything in that position to remide the situation. seemed to make scence to me.
ps. sorry if this is a bit off topic, but i thought it may help with your bush choices
truenosedan1
July 2005
Re: Sprinter suspension bushings Fri, 22 July 2005 18:39 Go to previous messageGo to next message
UPGRADE the the bushes, dont replace with stock crap! the rubber isnt exactly hard.., i got some steering rack bushes, i got rid of them as soon as i found poly ones
and $300! that is a fucking RIP off!
poly ones are very cheap
September_Squall
Melbourne, Australia
March 2005
Re: Sprinter suspension bushings Sat, 23 July 2005 01:48 Go to previous messageGo to next message
Who is "truenosedan1"?
Question
truenosedan1
July 2005
Re: Sprinter suspension bushings Wed, 27 July 2005 17:03 Go to previous message
truenosedan1 wrote on Sat, 23 July 2005 04:09
Previous Topic:import 4age and petrol types
Next Topic:Sparkly bits in gearbox oil
Current Time: Thu Sep 10 13:44:05 UTC 2026
Total time taken to generate the page: 0.0060110092163086 seconds
