Toymods » Tech & Conversions » KE30 Knocking?
rehau
KE30 Knocking? Fri, 22 July 2005 04:24 Go to next message
Hey, my ke30 is making a knocking sound, my first thought was that the motor has a bottom end knock but i dont really know much about bottom end knocking, with a bottom end knock is it always knocking or does it start knocking at idle, mine knocks below normal idle speed, (got weber 32/36 needs to be tuned) my other thought is the tail shaft uni joints are rooted, or my other thought was then when it's ideling rough its shaking somthing on the car. any help would be much apreaciated.
cheers Paul.
pheonix83
Devonport Tasmania
Re: KE30 Knocking? Fri, 22 July 2005 07:33 Go to previous messageGo to next message
if you apply a small amount of throttle while in neutral does the knocking speed up.
or does it only happen when you are driving it, or does it only happen when u rev the shiat out of it.
rehau
Re: KE30 Knocking? Sat, 23 July 2005 00:10 Go to previous messageGo to next message
while im in neutral and i give it a rev the knocking stops, it only starts knocking when the idle drops lower than normal and the motor starts shaking a bit. doesnt knock when i rev the shit out of it, and doesnt happen when im driving it, only when at shitty idle.
pheonix83
Devonport Tasmania
Re: KE30 Knocking? Sun, 24 July 2005 03:11 Go to previous messageGo to next message
is it a 4k motor.
IT sounds like the timing is out.
my old 4k used to do the same.
knocked its nuts off when idle and fine when u rev it.
reset your points, then reset your timing.
your probably running either too much dwell or too little.
rehau
Re: KE30 Knocking? Sun, 24 July 2005 06:58 Go to previous messageGo to next message
its a 3k motor, and is running electoric dizzy, timiing is set to 10 degrees before tdc, i think i found a possible cause, theres a bracket which the exhaust guy didnt un bolt but cut through it, and is probably knocking against the extractors so , i'll remove the bracket and see what happens.
aeke
Re: KE30 Knocking? Mon, 25 July 2005 03:22 Go to previous message
try running it for a few seconds with out the fan belt. It maybe the alternator or water pump???
Previous Topic:4AGZE stuttering problem
Next Topic:ea falcon aircon pulley on sc12?
Current Time: Sun Oct 25 00:40:15 UTC 2026
Total time taken to generate the page: 0.0046191215515137 seconds
