Toymods » Tech & Conversions » 5-Lug Hubs
aussie260z
April 2005
5-Lug Hubs Fri, 22 July 2005 04:44 Go to next message
Just wondering what you guys thought, whether or not these hubs would be suitable,
Here are some pics,
http://album.hybridz.org/showphoto....&cat=500 &page=1
The rotor would have to bolt onto the face of the hub,
The inner and outer bearings are spot on and the offset from the hub face to the spring perch is pretty much identical from the original hub to the aftermarket 5-lug hub,
These new 5-lug hubs are supposed to be good for 500kg a corner and my engineer has said they should be okay but might be an idea to use stronger studs, he hasnt seen it yet though,
What yall think???
Re: 5-Lug Hubs Fri, 22 July 2005 06:15 Go to previous messageGo to next message
Your links dont appear to be working.
aussie260z
April 2005
Re: 5-Lug Hubs Fri, 22 July 2005 06:26 Go to previous messageGo to next message
Try this...........
http://album.hybridz.org/showgallery.php?cat=500&a mp;ppuser=12400
First two pics
M.W.P.
Rocky Mountains, Canada
Re: 5-Lug Hubs Fri, 22 July 2005 07:29 Go to previous messageGo to next message
If its fits, is strong enough and the offset is correct, get em.
What price though?
aussie260z
April 2005
Re: 5-Lug Hubs Fri, 22 July 2005 08:29 Go to previous messageGo to next message
$29.95 a side from Supercheap Smile
Re: 5-Lug Hubs Fri, 22 July 2005 11:16 Go to previous messageGo to next message
can you list the bearing & seal part numbers?
(that's not a trailer hub is it?)
Re: 5-Lug Hubs Fri, 22 July 2005 13:16 Go to previous messageGo to next message
from the pic it looks a little flimsy.... large flat flange with fairly sharp corner at the base onto a skinny bearing carrier... might be good fro trailer but wouldn't want to see it near a Z car Shocked
then again, what do i know, it might be pefectly fine Very Happy
heh heh, they are cheap enough to test at least one to destruction Razz
http://album.hybridz.org/data/500/medium/P1010004.JPG
[Updated on: Fri, 22 July 2005 13:17]
rsdeo
Burlington, On. Canada
Re: 5-Lug Hubs Fri, 22 July 2005 19:26 Go to previous messageGo to next message
oldcorollas wrote on Fri, 22 July 2005 09:16
I think I know where they came from. I made this one up myself for a test fit.
http://img344.imageshack.us/img344/8927/hub5x11432cu.jpg
aussie260z
April 2005
Re: 5-Lug Hubs Fri, 22 July 2005 23:00 Go to previous messageGo to next message
Its a trailor Hub from Arkengineering, part # FH150,
Im going to show it to the engineer next week and see what he says,
But ive taken some measurements of this bugger and i think im going to have a really hard time finding anyone rotors that will slip over it and be a nice tight fit,
Jayem
Finland
Re: 5-Lug Hubs Sat, 23 July 2005 00:47 Go to previous messageGo to next message
BMW rotors might fit. Just need to re-drill the stud pattern and lathe a centering ring. My Crown drum hub looks similar and I have BMW rotors.
aussie260z
April 2005
Re: 5-Lug Hubs Sat, 23 July 2005 01:05 Go to previous messageGo to next message
Jayem, What would you attach the centring ring to, the hub or the rotor?
Or does it just side down on the hub?
Jayem
Finland
Re: 5-Lug Hubs Sat, 23 July 2005 01:17 Go to previous messageGo to next message
With "compression fit" to hub.
I could take pics of my solution.
aussie260z
April 2005
Re: 5-Lug Hubs Sat, 23 July 2005 01:45 Go to previous messageGo to next message
I would love to see some pics mate Smile
Allan
Re: 5-Lug Hubs Sat, 23 July 2005 04:57 Go to previous messageGo to next message
brave man fiting trailer hubs to the front of your car!
aussie260z
April 2005
Re: 5-Lug Hubs Wed, 27 July 2005 08:23 Go to previous messageGo to next message
Thats what the engineer thought,
He liked my engine mounts, said he wouldnt pass my car with the trailor hubs..............
Re: 5-Lug Hubs Wed, 27 July 2005 08:48 Go to previous messageGo to next message
obviously a bit too brave for the engineer Laughing
seriously: how hard would they be to machine out of a lump of suitable steel - assuming that you could get access to a CNC mill ? could you use a light alloy that's machinable?
aussie260z
April 2005
Re: 5-Lug Hubs Wed, 27 July 2005 09:17 Go to previous message
I looked at alot of hubs from other cars over the last couple of days and they looked alot stronger than the dodgy trailor hubs i saw on some early Volvo's,
I looked at Jags, Volvo's, Fords, Holdens, Nissan, none were really that suitable,
Buts its truly amazing how many cars use the same bearings as the zed,
Like every Holden made between 1957-1990, most 60's & 70's fords, lots & lots of Toyota's, every Volvo from 1968-85 & heaps of Nissans/Datto's,
But no hubs really suited,
All of them had weird offsets and the distance between the bearings was always off, so the hubs would have required machining,
BUT.............the problem is solved, ive managed to track down some Hubs from Hoppers Stoppers in Melbourne made from K1045 Steel, supposed to be strong stuff, rated at 630 Mega-Pascals (whatever that means) but supposed to be high-tensile steel, engineer said that would be fine,
Its got the correct offset, has a 5-stud Nissan Pattern, which is a Ford/Mitsubishi and some Toyota (5 by 114.3mm),
Brand new with new Bearings, seals and caps $320/Pair,
Engineer frowned upon using alloy hubs for street use,
The engineer liked my engine mounts/gearbox crossmember though...........YAY!!!
Also found hubs that might have been a possibility made from Billet 4140 steel, this stuff is supposed to be a tad bit stronger, rated at 770-930 Mega-Pascals Smile, but much much much harder to machine,
[Updated on: Wed, 27 July 2005 09:20]
Previous Topic:HKS F-con on MAP engine
Next Topic:Suggestions for KE 55
Current Time: Wed Oct 14 19:54:36 UTC 2026
Total time taken to generate the page: 0.14908885955811 seconds
