Toymods » Tech & Conversions » chaser radiator
Chris Davey
sunny coast, qld
chaser radiator Sat, 23 July 2005 05:57 Go to next message
Has any one used a chaser radiator in a cressida? I have a jzx90 chaser radiator in my corona and the end tanks are leaking and I have been told by radiator place that they can't get new end tanks for these.
So is a cressida radiator the same dimensions as a jzx90 chaser radiator? I measured my radiator to be 730mm by 460mm. Any help would be appreciated Smile
1JZ.747
Osama's hideout
Re: chaser radiator Mon, 25 July 2005 04:17 Go to previous messageGo to next message
no the same chris
jzx81 is 5mm wider than the mx83 radiator, cant get a top tank to strecth either.
the jzx90 is vastly different, maybe a jzz30 soarer one would be pretty similar.
though you will always end up with tank availability. i would look at getting something local to bolt into it and mix and match hoses or make custom hoses from stainless steel and use silicon to join them.
Chris Davey
sunny coast, qld
Re: chaser radiator Mon, 25 July 2005 07:26 Go to previous message
Thanks mate.
Yeah, I am already mixing and matching hoses and it is working. I will have to find one that is very similar in size and hopefully mounting brackets also. Hoses are no problem I don't think.
Previous Topic:3TGTE balance shaft
Next Topic:How long is my 7M going to last?
Current Time: Sat Oct 24 01:02:52 UTC 2026
Total time taken to generate the page: 0.0036420822143555 seconds
