Classifieds » Parts Wanted » rt141 corona rear brakes
ta22boy
Townsville
May 2005
rt141 corona rear brakes Sat, 23 July 2005 10:56 Go to next message
hey im chasing a complete rear disc assembly (calipers,mounts,rotors) off a rt141 corona to put on my ta22, i would also be interested in buying the whole diff housing if frieght wont be too much...cheers
scott
4DaDrift
Re: rt141 corona rear brakes Sat, 23 July 2005 11:20 Go to previous messageGo to next message
so yoru either after a st141 or rt142
are you after drum
disc
disc with irs
disc with either irs or lsd ?
ive an st141 avante if its of interest yet im not willing to seperate the car
brett_celicacoupe
townsville NQLD
Re: rt141 corona rear brakes Sat, 23 July 2005 12:29 Go to previous messageGo to next message
he needs it from a lve axle rear end.
"gold28" was selling a set a while ago and they were off a RT141 Confused
i also though it was either st141 or rt142 but i dont know coronas that well Confused
brett_celicacoupe
townsville NQLD
Re: rt141 corona rear brakes Sat, 23 July 2005 12:39 Go to previous messageGo to next message
this is exactly what he wants
gold28 wrote on Wed, 16 March 2005 19:40
Here is the corona RT141 brake info for ya.
Disk Diameter = 280mm
Disk thickness = 9mm (solid)
Pads are approx 100x30mm
Single Piston, approx 40mm diameter
Internal Drum handbrake didn't measure diameter but who really cares about that anyway.
Not the most impressive of brake setups but they are easy to work on and pretty much hassal free (unlike) the XE falcon discs I had to pull apart last weekend, what a shocker of an engineering effort that is.
And you they will bolt up to the MX23 F series axle, also a T series and an E series (provided they are the same stud pattern). You will need to sort out handbrake cables. i have the corona ones but i have not tried to fit them into the celica so I can't comment. Also the solid brake lines on the diff housing need to cut and flared to accept the caliper hose.
Anyhow here are some photos
http://www.members.optusnet.com.au/nez_tony/IM001273.JPG
http://www.members.optusnet.com.au/nez_tony/IM001274.JPG
http://www.members.optusnet.com.au/nez_tony/IM001275.JPG
4DaDrift
Re: rt141 corona rear brakes Sat, 23 July 2005 16:38 Go to previous messageGo to next message
confirm what theyre off and i might be abel to organise soemthing
pm me Smile
brett_celicacoupe
townsville NQLD
Re: rt141 corona rear brakes Sun, 24 July 2005 09:22 Go to previous messageGo to next message
brett_celicacoupe wrote on Sat, 23 July 2005 22:39
Not the most impressive of .........
kawaii
Re: rt141 corona rear brakes Thu, 18 August 2005 03:25 Go to previous messageGo to next message
Hey..i have one RT141 diff for sale..
whole diff with the hand brake cable as well..
disc brake $ 150 in Victoria
brett_celicacoupe
townsville NQLD
Re: rt141 corona rear brakes Thu, 18 August 2005 09:26 Go to previous message
i just picked up my set today (disk brakes) and they cost me $20 from a wreckers - i think you will have to do a bit better than $150
Previous Topic:WTB: 100kw 4age distributor
Next Topic:WTB: SW20 Mr2 Standard Air Box
Current Time: Fri Nov 20 04:57:27 UTC 2026
Total time taken to generate the page: 0.0087881088256836 seconds
