Toymods » Tech & Conversions » jerky trailing throttle
jerky trailing throttle Sun, 24 July 2005 01:57 Go to next message
This has been a problem for a while now, and in stop-start traffic it's starting to piss me off.
When I go from trailing throttle to accelerating, no matter how lightly I tap on the loud pedal my car jerks into acceleration rather than making a smooth transition... any ideas on possible causes?
BlackSupra
Re: jerky trailing throttle Sun, 24 July 2005 02:12 Go to previous messageGo to next message
Bad tuning hesitation?
Lose tailshaft bolts
Too much play in the diff
Re: jerky trailing throttle Sun, 24 July 2005 06:48 Go to previous messageGo to next message
Is it factory ECU? If so, i'd say TPS is out of adjustment.
If its aftermarket.. Then more likely running a bit lean on that section of the map.
Re: jerky trailing throttle Sun, 24 July 2005 15:41 Go to previous messageGo to next message
tailshaft bolts are fine. diff is a possibility, but there have been no other symptoms of it gong out thus far.
it's an aftermarket ECU... you're suggesting it's running a bit lean on trailing throttle or on very low throttle?
Re: jerky trailing throttle Sun, 24 July 2005 20:21 Go to previous messageGo to next message
TurboRA28 wrote on Sun, 24 July 2005 16:48
it is DEFINITELY too lean on the trailing throttle Smile
i had zactly same issues when tuning the MS..
if you lean it out too much, as soon as you even touch throtle, it kicks and jerks..
two ways to adjust.
one is to bump up the acel enrich and decrease trigger V/s , but the prob is then you have fuel squirting in all over the shop.
better solution is to bump up the full trailing throttle values by a bit... depends how your ECU measures them Wink
i think for mine, i increased so that rather than being stoich at trailing throttle, it is just on the rich side (as measured by narrow band sensor) and it may only be a 1-2% (of max injector PW) that makes all the difference, which makes it what.. 0.1 to 0.2ms perhaps??
try setting a certain rpm band... sayy.. 3500rpm to have richer trailing throttle.., and then drive and see difference between 3500 and 4000...
anyhoo, easy fixed of aftermarket Wink
Re: jerky trailing throttle Mon, 25 July 2005 00:12 Go to previous messageGo to next message
ah bugger.
I purposefully pulled a bit of fuel from trailing throttle 'cause it was blowing a bit of smoke at idle. might have to put that back up and pull it out of the temp maps.
BlackSupra
Re: jerky trailing throttle Mon, 25 July 2005 09:17 Go to previous messageGo to next message
draven wrote on Mon, 25 July 2005 10:12
ah bugger.
This could have been a nice piece of information to let everyone know about at the start of the thread. Freak
kingmick
Banned by his request
moved to tamworth
Re: jerky trailing throttle Mon, 25 July 2005 09:57 Go to previous messageGo to next message
is it standard size throttlebody? sorry for asking but i cant remmeber is it MAP or AIR flow?.manual or auto im guessing manual{i know you like driving}.aftermarket computer or factory?.
mick
Re: jerky trailing throttle Mon, 25 July 2005 11:11 Go to previous messageGo to next message
ah bugger.
but how often do you trail the throttle at engine idle speed? the trailing throttle part of the map and the idle should be in completely seperate areas, so it should be easy to just tune the low kpa areas (like 20-40absolute kpa), whereas idle vac should be what? 5-0-80kpa (depending on cams)
why would you pull it out of the temp maps? that will only cause issues with warmup?
which ECU, what tuning parameters do you have available (not one with a stoopid "cruise map"?)
Re: jerky trailing throttle Mon, 25 July 2005 15:05 Go to previous messageGo to next message
microwreck.
correct story: a bit of fuel was pulled out of idle, a bit out of cold start. I can't imagine this would really affect my trailing throttle.
takai
Re: jerky trailing throttle Mon, 25 July 2005 15:58 Go to previous messageGo to next message
The other option in there is that the engine is rocking in the mounts. Common with a button clutch. A GZE which was being used in a clubman with a stacks (sp) clutch unit was jerky as all hell on trailing throttle. Its even more noticble in FWDs, such as a friend's AE82 GZE.
Re: jerky trailing throttle Tue, 26 July 2005 01:26 Go to previous messageGo to next message
well, I don't have a button clutch or a FWD Razz will have a looksee tho
takai
Re: jerky trailing throttle Tue, 26 July 2005 01:37 Go to previous messageGo to next message
Heh, i know you dont have a FWD. Come to think of it though, the sprinter is quite shakey at trailing throttle.... probably due to the almost solid engine mounts Smile
Re: jerky trailing throttle Tue, 26 July 2005 04:07 Go to previous messageGo to next message
draven wrote on Tue, 26 July 2005 01:05
microwreck.
it's not trailing throttle as such (in terms of tuning where that sometimes refers to fuel pulled when throttle is closing).. but decel with closed throtle..
this will put your MAP around 20-40kpa absolute, so all ya need to do is to bump the fuel up a percent at a time in that region and you will tune it out..
i admit i am not familiar with the microlebs, but surely you have an actual 2D map of rpm vs MAP to tune from?
any online software i can download?
kingmick
moved to tamworth
Re: jerky trailing throttle Tue, 26 July 2005 05:24 Go to previous message
prob pulled a bit to much out comibined decel and cold start.just creep up on it a bit.
mick
Previous Topic:starlet vs. ae86?
Next Topic:AE86 JDM Fuel Pump Relay
Current Time: Wed Oct 28 08:12:29 UTC 2026
Total time taken to generate the page: 0.0057570934295654 seconds
