Toymods » Tech & Conversions » 1g q
something
newcastle
1g q Sun, 24 July 2005 08:26 Go to next message
My 1g last yesterday started only making 4 pounds as opposed to the usual 12.
and then today its only reaching 2 at best.
It runs standard computer and i have changed the boost controller with no help at all.Can any1 help me with what it could b i really hope you dont all say blown turbos
HyDrA
Adelaide, SA
Re: 1g q Sun, 24 July 2005 10:22 Go to previous messageGo to next message
Wastegate(s) not stuck open?
something
newcastle
Re: 1g q Sun, 24 July 2005 10:32 Go to previous messageGo to next message
should i be able to move them with my hand
VeeP
May 2005
Re: 1g q Sun, 24 July 2005 12:49 Go to previous messageGo to next message
If u have the heat shields off, u should be able to push them shut a lil bit - though it will be quite difficult
something
newcastle
Re: 1g q Mon, 25 July 2005 10:45 Go to previous messageGo to next message
Is there any other test i can do?? to check if it is the wastegate stuck open???
Re: 1g q Mon, 25 July 2005 12:46 Go to previous messageGo to next message
A leak in the inlet system is more likely than a stuck wastegate. Check all your hoses and connections.
something
newcastle
Re: 1g q Tue, 26 July 2005 07:33 Go to previous messageGo to next message
well wastegates and all hoses and lines are fine checked hoses with a smoke machine no leaks.
the car has now dropped from making 4psi to none at all so does any1 have any ideas now.
Re: 1g q Tue, 26 July 2005 07:40 Go to previous messageGo to next message
Hmm, you'd still see *some* boost if one of the turbos went I'd say. How did you check the wastegates? It's one thing for the hoses to all be fine, but that doesn't tell you if they are working at all. I gave mine a good coating with RP7 and used an air compressor with a gun attachment and pulsed them to make sure they weren't sticking at all. Still doesn't explain no boost at all Sad
something
newcastle
Re: 1g q Tue, 26 July 2005 08:08 Go to previous messageGo to next message
i could move them with my hand and hear them seating again.
Under the pressure could one be opening straight away.
They were pretty hard to move.
something
newcastle
Re: 1g q Wed, 27 July 2005 10:13 Go to previous messageGo to next message
do you think i should get my hands on some other turbos and give them a go see what happens
Re: 1g q Wed, 27 July 2005 10:33 Go to previous messageGo to next message
there should be a bit of spring pressure holding the wastgates closed? perhaps fire up engine while you look at them and see if they move when the engine isn't under load?
cheers,charles.
something
newcastle
Re: 1g q Wed, 27 July 2005 10:36 Go to previous message
yeah ive done that and all seams to be fine
Previous Topic:How do u remove the dials from the dash cluster AE86
Next Topic:Recaro SR3 AE86 Question
Current Time: Sun Nov 22 07:19:25 UTC 2026
Total time taken to generate the page: 0.0083770751953125 seconds
